88 crx - ls/vtec
Old Feb 17, 2003 | 07:02 PM
turbodav's Avatar
Default 88 crx - ls/vtec
started off as ls block here
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
these are the pistons i used
block is half way done here
here is the before picture of the block with the oil cooler and no nipple for coolant
here it is with the hole drilled out for the coolant nipple to connect to the oil cooler
here is the before picture of the motor
and the after picture
in the future adding type r intake manifold holly 68mm TB, Greddy exhaust, and most important hondata
[Modified by turbodav, 10:05 PM 2/17/2003]
[Modified by turbodav, 10:06 PM 2/17/2003]
[Modified by turbodav, 10:07 PM 2/17/2003]
Old Feb 17, 2003 | 07:31 PM
crx(gator)'s Avatar
Default Re: 88 crx - ls/vtec (turbodav)
what have you put in to reinforce the block so you can rev higher, other than that, looks nice...
Old Feb 17, 2003 | 07:42 PM
turbodav's Avatar
Default Re: 88 crx - ls/vtec (crxgator)
all new bearings,stock crank, stock rods w/arp bolts and jdm itr pistons
arp head studs ,jg engine dynamics valve springs and titanium retainers, jun stage 3 cams head milled 0.0010 inch.,0.0025 cosmic head gasket
that equals 11.75:1 compression
the car runs great it has about 215 miles on the motor now, just need to add hondata and i will be ready to go run at the track forgotten to mention that i am running a Y1 trans with factory LSD
[Modified by turbodav, 10:52 PM 2/17/2003]
[Modified by turbodav, 11:16 PM 2/17/2003]
Old Feb 23, 2003 | 06:17 PM
turbodav's Avatar
Default Re: 88 crx - ls/vtec (ruiner17)
i am looking for a greddy catback exhaust fo my 88 crx ls/vtec
Old Feb 23, 2003 | 07:02 PM
bodymodgrl's Avatar
How does you car run with this motor? What times are you getting? I was thinking about putting one in my CRX in May. I can't decide between that or supercharging the motor I have.
Old Feb 23, 2003 | 07:09 PM
turbodav's Avatar
Default Re: 88 crx - ls/vtec (bodymodgrl)
the car runs great just need to add hondata other than that it runs great
i will take it to the track when i get it tuned
Old Feb 23, 2003 | 08:41 PM
-16V-'s Avatar
Nice ls-v setup
Is the ls-v setup strong and reliable??
Thinking of doing it some day.....
Old Feb 23, 2003 | 10:37 PM
JaiDM's Avatar
Default Re: 88 crx - ls/vtec (1991_jdm_sleeper)
looks very very nice!!!
but i think you need new coolant hoses
demon_camber
Jan 29, 2010 10:56 AM
manthony14375
Oct 7, 2009 04:52 PM
ryanj1025
Nov 13, 2008 06:30 AM
DADADAAAMN
Jun 20, 2007 06:43 AM
tc ae86
13
Jun 29, 2005 10:20 AM
