Need help with swap!!!
Old Feb 17, 2003 | 03:21 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Need help with swap!!!
Im swapping a 92 LS into my 90 CRX dx. My question is...am i going to have to shorten my downpipe to fit with the stock cat and exhaust? If i do then how much will i have to get cut off? Also...are there any other options? I mean besides cutting/rewelding...can i use the LS header and the DX downpipe or something like that? Thanks.
Sean
Old Feb 17, 2003 | 04:31 PM
ThatRicerDaniel's Avatar
Default Re: Need help with swap!!! (sCeRaXn)
if you use the ls manifold and with the d series down pipe then it will all bolt up.
Old Feb 18, 2003 | 03:04 PM
Flexmyrex's Avatar
Default Re: Need help with swap!!! (NitrousDreamz)
"if you use the ls manifold and with the d series down pipe then it will all bolt up."
true
sfar785
Feb 19, 2010 01:22 PM
LS94tegra
Mar 29, 2009 07:57 PM
92integracer
Dec 24, 2006 09:00 PM
B!^A@
Nov 7, 2006 02:37 PM
oneforce
May 31, 2005 06:29 PM
