Are my cams acting up?????
alright, i have a 91 teg with a 94 engine, anyways i was driving home from work, and the engine light came on and the engine got really muffly and wouldnt let me go above 3k rpms, so i drove all the way home, turned the car off, looked under the hood, nothing loose or anything apearing to be wrong, then i turn it back on, nothing seems to be wrong, the lights gone and i have normal redline. i go get gas cuz i was pretty low, and then on the way home it does it again, i shut the car off when on the street and roll for 2 seconds then turn it back on, no problem, whats going on!
oh btw i have JG performance cams in the engine
[Modified by advancedjdm123, 10:45 PM 2/17/2003]
delete this post, find out what code your throwing, then repost with the code and symthom then you will get a helpful response.. pull out the carpet on the passanger side foot rest, put the car on the on position, and you will see the ecu and it will be flashing red dots.. go to http://www.g2ic.com and read the teg tips on how to read the codes for your ecu.. as long as you can read, you can do this, pretty simple..
mushu315
Jun 3, 2005 06:58 PM
