90-93 teg axle, dust seal removal?
Old Feb 17, 2003 | 01:25 PM
elmalouno's Avatar
Default 90-93 teg axle, dust seal removal?
""We will start with the Bottom intermediate shaft first, because it is the most common. It comes on most of the B16As and and all US 90-93 Integras. 95% of the time, the proper axle for this is the 90-93 Integra axles. For a good fit, the axles and car will have to be modified by removing the spacer in the hub and removing the dust seal on the outer joint. See the illustrations below.""
i am just having trouble seeing what they are talking about in this picture...
how do i get the dust seal off?
does this metal band need to come off? how do i do that? and if i do can i get it back on?
thanks guys....
Old Feb 17, 2003 | 01:37 PM
Tbone's Avatar
Default Re: 90-93 teg axle, dust seal removal? (elmalouno)
From that pic it looks like its already gone. It sits right on that first lip of the hub if you go from the nut to the shaft.
[Modified by Tbone, 5:45 PM 2/17/2003]
Old Feb 17, 2003 | 01:39 PM
ghettocrxsi's Avatar
Default Re: 90-93 teg axle, dust seal removal? (Tbone)
what u are pointing at with the screw driver is the axel boot clip.. if u take that off the axel boot comes off
The dust seal is on the actualy hub it self. its a round disk that just pull off
Old Feb 17, 2003 | 01:43 PM
elmalouno's Avatar
Default Re: 90-93 teg axle, dust seal removal? (ghettocrxsi)
i thought the spacer was in the hub and the dust seal was on the axle? maybe my axle didn't come with one?
Old Feb 17, 2003 | 05:06 PM
elmalouno's Avatar
bump cuz i don't get it, and i'd like to
Old Feb 17, 2003 | 05:31 PM
Malgerus's Avatar
Well, it's quite simple. The dust seal is on the inside of the hub, it goes around where the axle comes through. Simply take a screwdriver and jam it under. It should pop out. At least it did on my DX hub.
Old Feb 17, 2003 | 05:33 PM
NCchris's Avatar
the dust seal is on the knuckle, it will pry right off.
http://www.hasport.com/News/Articles...leinstall2.jpg
HTH
chris
Old Feb 17, 2003 | 06:23 PM
Tbone's Avatar
see the axle nut, follow with your finger to the splines , now to where the splines meet the hub where it gets big, there is usually a grove there where a rubber axle seal sits, it meets up with your wheel bearing and spindle.. so if you look at your own pic take the screwdriver and move it to the right (if your looking at the comp screen)
Old Feb 17, 2003 | 07:28 PM
elmalouno's Avatar
ok so i only have to worry about the spacer thing on the hub then... i was going by what this hasport said about the dust seal being on the axle... but i don't see any dust seal so either i am totally retarded(good chance) or the dust seal on the axle is already off...
Old Feb 17, 2003 | 07:44 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Your dust seal would be where the yellow arrow is, yours is gone.. the whole perpouse in removing the dust seal, is half on how it seats in the hub, and to allow it to sit deaper, which would alow the axle to stretch instead of being collapsed, and thats notorious on lowered cars, "binding axles" acting liek they are too long..
Old Feb 17, 2003 | 07:45 PM
Built B16A's Avatar
Default Re: 90-93 teg axle, dust seal removal? (Built B16A)
oh yeah, that clip you got on the screwdriver, its the tywrap for the CV boot.. don't take that off, it stays on.. you take that off, and its like busting your axel boot, you'll get grease everywhere, and just make a mess.. leave it alone.
Old Feb 17, 2003 | 08:03 PM
Tbone's Avatar
I told you it wasnt there in my first post.
Old Feb 17, 2003 | 08:16 PM
Built B16A's Avatar
hey man, im just pointin **** out.. dont' get your panties in a bunch.. heh
Old Feb 17, 2003 | 08:49 PM
elmalouno's Avatar
thanks for your help guys.,.. sorry tbone i didn't relize u had said that mine was missing.. anyways thanks!
Old Dec 1, 2003 | 04:04 PM
2k1_ITR_0736's Avatar
BTW the best way to get the best fitment on b16 swaps in ed's is to take a 87-89 integra outa hub and put it on the 90-93 inner hub. with the axle shaft from either axle. the reason being is the 87-89 integra hubs are smaller in length, therefore the dust sheild can stay there.
wow im a grave digger, my buddy linked me to this, and i had to post it up so peeps could get perfect fitment. hasport sells these axles i think.
dafreeeze
May 14, 2013 06:58 PM
90hbvtec
Oct 28, 2003 06:10 AM
type Gendy
13
Feb 3, 2003 10:51 PM
mobrep
Aug 29, 2002 03:06 PM
Crote
Jun 19, 2002 07:30 PM
