any one used integra type R suspension on a crx?
Old Feb 17, 2003 | 01:19 PM
slowassR's Avatar
Default any one used integra type R suspension on a crx?
Old Feb 17, 2003 | 01:46 PM
jdmhondageek's Avatar
Default Re: any one used integra type R suspension on a crx? (slowassR)
first it doesnt work very well. and the struts will most likely need the R forks. the springs are designed for a heavier car so what you end up with is a car that doesnt ride very well and is about as high as stock. so what the point?
Old Feb 17, 2003 | 02:06 PM
slowassR's Avatar
Default Re: any one used integra type R suspension on a crx? (Ayanami)
Just because it not slammed to the ground doesn't mean it will not perform well. Yes, the spring rate is higher for a heaver car. Still type R suspension is relatively soft. I'm not sure how the difference in weight would effect the performance of the stock type R suspension. I don't think it would handle too poorly though. I'm sure it would be much better than some pieced together aftermarket coilover kits.
Im sure it would need the type R "forks"
I was asking if any one has used the type R suspension on a rex? I see that almost no one has used the 5 lug conversion.
Old Feb 17, 2003 | 02:54 PM
bryant's Avatar
No one has done five lug on a crx? HAHA! Please use search, this has been braught up hundreds of times.
Old Feb 17, 2003 | 03:10 PM
slowassR's Avatar
Default Re: any one used integra type R suspension on a crx? (Bryant)
I was asking if any one has used the type R suspension on a rex? I see that almost no one has used the 5 lug conversion.No one has done five lug on a crx? HAHA! Please use search, this has been braught up hundreds of times.[/QUOTE]
http://battlecat.8m.com/ITR%205%20lug%20on%20DA.htm
http://jarofbees.com/tech/da_5lug/
I dont see many people useing 5 lug on a crx. If you have any thing that would help me know more about 5 lug on a rex or abs on a rex?
Old Feb 17, 2003 | 03:22 PM
bryant's Avatar
Thanks for the help Luke
Old Feb 17, 2003 | 03:42 PM
slowassR's Avatar
- I just got a new rex and im excited to get this thing going. i hope someone can send me some usefull info
Edit: That i have not found already ... i have been looking everywhere.
[Modified by slowassR, 7:43 PM 2/17/2003]
Old Feb 17, 2003 | 04:15 PM
bryant's Avatar
I thaught I just IMed you everything you needed? I can give pics of it done if you like. But everything you posted and What I gave you is all your going to need. Once you start it and have problems, then post up.
Old Feb 17, 2003 | 04:45 PM
HondaRcB's Avatar
I'll be putting ITR shocks/springs on my 1990 Civic Wagon using 88 CRX lower control arms in a few weeks. I'm looking foward to it
Old Feb 17, 2003 | 05:25 PM
slowassR's Avatar
Default Re: any one used integra type R suspension on a crx? (HondaRcB)
excelent!! im pretty srue you will love the way it handles! Ill keep my eye out to see how you like it.
Old Feb 18, 2003 | 12:00 AM
Radex's Avatar
Last summer I had to sell my suspension and before got a new one I put ITR stuff just for fun. Front forks are nothin special "R" stuff, yes you can use it but they are exactly the same (same OEM number) as Civic 92-95 so you can end up by getting these. I have B18C6 in my CRX so it is not the lightest car. With 'R' struts/springs car is really high, I guess higher then stock, anyways it drives somewhat better then stock because 'R' stuff is stiffer (better quality?). If you want performance I don't recommend that swap, with basic Konis you get better handling no doubt.
Old Feb 18, 2003 | 02:11 PM
slowassR's Avatar
Default Re: any one used integra type R suspension on a crx? (Radex)
Thaks for the info Radex.. that what i was asking.
Old Feb 18, 2003 | 02:48 PM
Ef Whore's Avatar
Type-R suspension seems pointless in a EF, because,umm, its for a type-r! Oh I forgot that its makes people feel cool to have a extra lug that IMO does absolutlely nothing. Complete waste of money. Flame all you want.
Old Feb 18, 2003 | 03:49 PM
yoshi234's Avatar
I shoot brides
i put on ITR neuspeed front springs and ITR stock rear springs(ITR lca's), all on stock ITR shocks on the wagon couple weeks ago. The rake is a bit much so neuspeed ITR rear springs will be going on soon also. Handles way better than the stock EE2 chitls
yshi - who still has alot more work to do on the EE....
Old Feb 18, 2003 | 03:56 PM
bryant's Avatar
Default Re: any one used integra type R suspension on a crx? (Ef *****)
LOL! they dont do it for the lug. Its for the brakes!
Old Feb 18, 2003 | 06:08 PM
slowassR's Avatar
Yosi- is that the beater
Type-R suspension seems pointless in a EF, because,umm, its for a type-r! Oh I forgot that its makes people feel cool to have a extra lug that IMO does absolutlely nothing. Complete waste of money. Flame all you want.LOL! they dont do it for the lug. Its for the brakes!
yup brakes are my main objective. I also have type R wheels from my R. SO.. I can get new wheels for the r and I already have some parts. I was thinking the same with suspension. I could get a lowdown kit for the R and use the R suspension for the rex. I guess well see how it goes.
Old Feb 18, 2003 | 11:08 PM
ProTreeCRX's Avatar
would ITR front upper control arms fit into an 88 crx with stock suspension. reason im asking is because i have 2 itr UCA and my stock UCA got fucked up ball joints.
Old Feb 19, 2003 | 10:22 AM
slowassR's Avatar
Default Re: any one used integra type R suspension on a crx? (MnC CRX)
You may want to make that a new post. You would have better luck finding your answyer.
Old Feb 20, 2003 | 09:05 PM
nonvtec allmotr's Avatar
The rear setup will work all of it,but the 88 crx rear control arm r the same as type R, The front setup will not work .It will make you have positive camber and its not good at all. I would put 90-93 Int. front and back on it .they stop great.
Old Feb 21, 2003 | 12:53 AM
evilxkid's Avatar
Default Re: any one used integra type R suspension on a crx? (nonvtec allmotr)
if you want to get it for the brakes you should consiter getting the 96 type r suspention. same brakes in a 4 lug at half the price. b18c1_powered_si sell's them for 800 with every thing.
i put the same thing on my hatch and it's way better don't let any one tell you diffrent.
the itr upper controll arms wont work either, you have to use your stock one's. sorry!
btw there 4x114 also(like a prelude or accord).
Old Feb 21, 2003 | 04:13 AM
Ham'ed Hatch
Guest
Posts: n/a
werd.
oh and if you're doing it for brakes, you need to work on your searching skills. there was a whole like 3 page post on how pointless it is to swap type r crap for brakes. Driven oWnEd everybody on the subject .
Old Feb 21, 2003 | 04:44 AM
E-AT_me's Avatar
Default Re: any one used integra type R suspension on a crx? (Ham'ed Hatch)
stock size brakes work great for me.. and they're cheaper.. but if you have the parts, that's the only way i'd do it..
Old Feb 21, 2003 | 04:54 AM
essex's Avatar
Default Re: any one used integra type R suspension on a crx? (Rexman)
No its not the same brakes as the 5 lug R, the 4 lug R brakes are the same as 92-96 integra brakes(except for the bolt pattern)...nothing special unless you think integra brakes are special.
Old Feb 21, 2003 | 12:42 PM
evilxkid's Avatar
Default Re: any one used integra type R suspension on a crx? (essex)
if this is true why cant i fit 14's on my car.
ps driven owned no body.
Old Feb 21, 2003 | 12:59 PM
essex's Avatar
Default Re: any one used integra type R suspension on a crx? (evilxkid)
14 what? 14 teg wheels or something else...
the 96 R brakes were not the 11" brakes on the 5 lug R
