what camber kit yoo running . . . ?
i'm in search for a good front/rear camber kit . . .
what camber kit are yoo running and what do yoo think of the quality and performance of the camber kit ?
thanx alot . . . and where can i get it and how much ?
i heard skunk2 were good but they have no rears . . .
ignalls but they look crappy . . .
[Modified by - [ b16a2 ] -, 3:56 PM 2/17/2003]
i have ingalls front and rear on my si and it does fine
3 degrees correction each way
i got mine through www.ardperformance.com for a decent price
cant remember what it's set to but my car is lowered but not slammed (2 finger gap between tires and fenders)
Rear kit is $5 with some washers and bolts, but the front is a different story. I still dont have a front kit because I havent really found one I like, I have heard good things about the SRR kit but I dont know who to get it through. (If you know send me a PM)
skunk on the front
ingals on rear
the ingals has more than enough adjustabllity and poly bushings, but you have to PILE the grease on or else you will be tortured by squeeks.
bith kits do the job though
ingals on rear
the ingals has more than enough adjustabllity and poly bushings, but you have to PILE the grease on or else you will be tortured by squeeks.bith kits do the job though
I have the Ingall's polyurathane kit on front and rear. They squeak like a ****. I should have gone with Skunk2 on the front. But then again, my front and rear kits where free
I might take them off and sell them and go with the Skunk2 on the front and SRR on the rear.
[Modified by Damon, 3:40 PM 2/17/2003]
i have a full ingals kit. the rears are pretty good. i have no complaints about those. the front however have pissed me off. ingals uses low grade bolts. i rounded the heads on mine far to easily. never use the castle nut they supply you with the the ball joints
use your factory ones.
that must be a ball joint kit. I personally wouldnt trust it...
I have heard stories about people's shocks rubbing against other suspension parts becuase of ball joint kits.
None at the moment.
I would like to go with the Skunk2 fronts upper arms and bolt/washer in the rear.
Also, i have installed Ingalls kits before. They are pretty decent...
anybody know where i can get SSR rear camber kit ?
come on people list INFORMATION
thanx
thanx
http://www.aj-racing.com/
Hit up ghettoracer here on the board. He sells them...
https://honda-tech.com/zerouser?cmd=viewprofile&id=6158
[Modified by JV, 8:10 PM 2/17/2003]
I have a skunk2 kit for my Eg and had one on my Ek. 4 degrees of adjustability and no clearance problems.
For the rear longer bolts and washers 0wned!
