Leaking oil??
Old Feb 17, 2003 | 10:08 AM
AGPSuperstar's Avatar
Default Leaking oil??
im leaking oil out of my valve cover....do i have a blown head gasket?? help me out masterminds...thanks
Old Feb 17, 2003 | 10:28 AM
Vinceg99's Avatar
Default Re: Leaking oil?? (AGPSuperstar)
What about a bad valve cover gasket??!!
Old Feb 17, 2003 | 10:32 AM
tpr's Avatar
tpr
Depends on where its leaking. If it leaks from the valve cover only then replace the rubber gaskey and the grommets. Be sure to use a littel grey RTV at the places where the gasket has to make the 90 angle (at the cam(s)). Tighten the 10 mm nuts till they stop turning with reasonable effort for a 10 mm bolt.
If the leak is at the head block joint, then it could be a heat gasket. Are there any other symptoms ( miss, overheating, oil mixing with the coolant, coolant mixing into the oil. (Both will look creamy/foamy off white)) Check the compression it should vary no more than 10% cyliner to cylinder.
Give us more information so we can better diagnos the problem!!!!
Old Feb 17, 2003 | 10:47 AM
Default Re: Leaking oil?? (tpr)
well....its coming out of the front of the valve cover....the crack between the cover and the block?? mayb??
Old Feb 17, 2003 | 11:26 AM
tpr's Avatar
tpr
The valve cover ends at the top of the head. The head gasket is between the head and the block.
Old Feb 17, 2003 | 11:28 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
ide put money he's talking about the valve cover gasket.. but ya never know, he should prolly do the cam seal too.. its like $7 at honda.. way cheaper than that gasket.
Old Feb 17, 2003 | 12:03 PM
Default Re: Leaking oil?? (Built B16A)
well nevermind....i believe it is the valve cover gasket.....how do i fix it?? any help appreciated...thanks guys
Old Feb 17, 2003 | 12:15 PM
BLAP BLAP!!!
Guest
Posts: n/a
take the valve cover off. throw away the gasket.. but in new gasket.. spread honda bond on corners.. then put back on.. not that difficult homie.
Yuta
Dec 12, 2015 05:27 PM
ted
Mar 18, 2005 08:03 PM
sleepyIntegra
May 26, 2004 03:43 AM
slowls
Jun 25, 2003 10:24 PM
Tegra
Nov 16, 2002 11:33 AM
