Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Soft springs or loose sway bar?
Old Feb 17, 2003 | 09:56 AM
Driven's Avatar
Default Soft springs or loose sway bar?
I'm trying to figure out what causes all the sway in my car. My guess is that I have soft springs... The sway isn't really a problem except that the suspension compresses quite a bit where i start rubbing the tyres.
I have koni yellows and intrax springs (basic street springs).
any other ideas? Would stiff springs help fix the sway? I'm looking specifically at the rear wheel and the rear bumper on the left side compared to the right side.
[Modified by Driven, 10:57 AM 2/17/2003]
Old Feb 17, 2003 | 11:32 AM
Lo-Buck EF's Avatar
Default Re: Soft springs or loose sway bar? (Driven)
i take it you are on race tires. so with the grip that they make that may be too much for off the shelf springs. esp with them being lowering springs, but not race orented they probably arent that stiff.
Old Feb 17, 2003 | 11:48 AM
Eee Pee's Avatar
Default Re: Soft springs or loose sway bar? (SOLOef)
Nothing stiffer springs can't solve....
Old Feb 17, 2003 | 04:22 PM
Driven's Avatar
Default Re: Soft springs or loose sway bar? (Eee Pee)
That's what i'm thinking, just needed some confirming opinions.
Thanks!
Old Feb 18, 2003 | 01:42 AM
travis's Avatar
At a given weight, higher spring rates will compress less distance than lower spring rates. Problem solved
Old Feb 18, 2003 | 02:18 AM
89civicdx's Avatar
Default Re: Soft springs or loose sway bar? (travis)
stiffer springs
or play with some progressive bumpstops in the rear if you don't want to change your suspension.
[Modified by 89civicdx, 3:58 AM 2/18/2003]
BKJJ77
13
May 7, 2012 10:29 AM
LowTec MOHawk
Honda Civic (2001 - 2005)
Oct 3, 2006 10:40 AM
JohnQPublic
Suspension & Brakes
Aug 2, 2006 04:41 AM
madhatter07
Jul 15, 2005 06:29 PM
Rev-Olution
Feb 26, 2004 11:33 PM
