need help installing ingalls camber kit
Old Feb 17, 2003 | 07:01 AM
civictypenos's Avatar
Default need help installing ingalls camber kit
its a new kit,going into a 95 civic,im guessing its the 1-3 degree adjustable kind.i got them in there easlily,but what i was wondering,there is a ring around the base of the bolt that goes into the body,should i remove this ring.its kinda like a spacer,i would think that it should fit up into the hole.but it does not fit up into the hole.So with it one there the camber peice does not sit flush,it sits on the ring.its kinda hard to explain if you have never installed one.if i remove the ring the whole piece would sit flush up into it.it just does not look right sitting on the ring.
Old Feb 19, 2003 | 10:37 AM
civickid77's Avatar
Default Re: need help installing ingalls camber kit (civictypenos)
Me too, i need some instructions on installing a front camber kit on a 99 LX 4dr
Old Feb 20, 2003 | 07:38 AM
some one here must have installed a ingalls kit before?????????????
Old Feb 20, 2003 | 07:42 AM
93civEJ1's Avatar
i have the ingalls kit on my car...i dont think the alignment shop used the ring on the kit...i think they just replace the old camber assemble and should fit like stock..good luck to ya.
killakalipoph
Honda Fit
Jun 25, 2008 03:17 AM
siguy9900
16
May 13, 2008 07:05 PM
itsJDMyo
13
Jan 7, 2005 10:40 AM
SubieDude
Apr 7, 2003 07:10 AM
