Leak from intake manifold gasket causes low or high idle?
Old Feb 17, 2003 | 01:23 AM
ULTRA911's Avatar
Default Leak from intake manifold gasket causes low or high idle?
just need a couple of replies, thanks!
[Modified by ULTRA911, 10:24 AM 2/17/2003]
Old Feb 17, 2003 | 05:13 AM
91DA9's Avatar
Default Re: Leak from intake manifold gasket causes low or high idle? (ULTRA911)
High Idle.
Old Feb 17, 2003 | 08:22 AM
Hybridhonda561's Avatar
Default Re: Leak from intake manifold gasket causes low or high idle? (94IntegraGSR-OVR)
definalty!
Old Feb 17, 2003 | 09:43 AM
1bad-eg's Avatar
Yes it can.
Old Mar 3, 2003 | 06:25 AM
blacksheep's Avatar
Default Re: Leak from intake manifold gasket causes low or high idle? (1bad-eg)
Can this be fixed without going through the trouble of changing the gasket? Is there some kind of sealant that can be put around the edges of the gasket?
Old Mar 4, 2003 | 03:39 AM
1bad-eg's Avatar
Default Re: Leak from intake manifold gasket causes low or high idle? (blacksheep)
Nope, you have to change the gasket.
Old Mar 4, 2003 | 10:00 AM
lizrdboy's Avatar
If it is the upper gasket, its not a big deal to replace. Takes about 15-20 minutes to take off, replace the gasket and re-attach the intake plenum. The lower gasket requires a little more effort. A vacuum leak like that will cause more than a high idle, though.. you will probably be running pretty rich and have a crappy idle as well. rough, etc. Possibly throwing EGR codes as well.
singlecammin
Jan 20, 2011 07:20 PM
Morasso
Feb 3, 2008 10:00 AM
ericstambaugh07
Mar 13, 2007 05:10 PM
Nicaraguense13
May 26, 2006 04:07 AM
SimplyTron
Jan 26, 2006 08:19 PM
