99 Civic Si A/C bracket same as P54 del sol?
Old Feb 17, 2003 | 01:16 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default 99 Civic Si A/C bracket same as P54 del sol?
Is the 99-00 Civic Si A/C bracket the same as the Delsol's P54?
Old Feb 17, 2003 | 01:21 AM
RR98DX's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (GapxGuy)
no. its the same as a GSRs...the 99-00 Si uses the bigger compressor.
[Modified by RR98DX, 2:21 AM 2/17/2003]
Old Feb 17, 2003 | 01:23 AM
GapxGuy's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (RR98DX)
Crap, so the 99 Si bracket won't work with my B20 in EK swap?
Old Feb 17, 2003 | 01:35 AM
GapxGuy's Avatar
Is this true?
http://www.jspectuning.com/6gen/
Old Feb 17, 2003 | 02:14 AM
97hb's Avatar
If it says p54 on it, it should work.
Old Feb 17, 2003 | 07:52 AM
GapxGuy's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (97hb)
The thing is that I ordered it and haven't received it yet. I want to cancel the order if it's different. The part number it give me when I ordered the 99 Si ac bracket is 38930-P30-000. I want to change it before it gets shipped out. Anyone know if they're the same??
Old Feb 17, 2003 | 05:10 PM
frankdatank's Avatar
i dont think its the same. i have a 96 hatch and used a delsol vtec ac bracket for my b18, it worked perfect.
Old Feb 17, 2003 | 05:59 PM
chopstikkeg's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (hybridcoupe97)
hey gapxguy i seen your kar around orange kounty a couple time, your kar it very kleans bro.
Old Feb 17, 2003 | 06:01 PM
rathead's Avatar
n o they are not the same
[Modified by rathead-ek, 9:02 PM 2/17/2003]
Old Feb 19, 2003 | 12:00 PM
GapxGuy's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (chopstikkeg)
Really? Thanks. Okay, so I'm getting the P54, case closed.
Old Feb 19, 2003 | 01:58 PM
2point0VTEC's Avatar
the 9si ac mount will work with your b20 into a ek swap...i'm using the si mount on my b20 right now and i got a ek also...
Old Feb 19, 2003 | 02:08 PM
Foozball26's Avatar
Default Re: 99 Civic Si A/C bracket same as P54 del sol? (2point0VTEC)
they will both work, think about how the motors are setup, b-series engine in a civic chasis, del sol and si are the same, may not be the same part number but they both work.
deviant1
Apr 10, 2003 05:42 PM
GapxGuy
Feb 17, 2003 01:01 PM
GapxGuy
Sep 4, 2002 09:45 PM
allmtr
Jul 29, 2002 01:51 PM
