need help on bottom end rebuild B18b
Old Feb 16, 2003 | 11:48 PM
UltRaH22's Avatar
Default need help on bottom end rebuild B18b
im rebuilding my block this yr to run high compression and NOS... im going with prolly the 10.5:1 comp and eagle rods, blockgaurd and all new OEM gaskets... my main question is i heard the ITR oil pump is a good cheap upgrade and will fit... now can i use that and still use a LS water pump/timing belt set up? would the ITR/ GSR waterpump be an upgrade or fit?
if it matters.... my set up will be on the stock head for now... and im planning on runnin a 75-100 shot (ZEX) with all the fuel upgrades incase u need to know that
whatVTEC
Jun 11, 2007 05:39 AM
whatVTEC
Jun 1, 2007 12:55 PM
psegs80
Oct 18, 2005 10:15 PM
volcom40street
17
Aug 6, 2004 11:10 AM
