window keeps falling off rail
Old Feb 16, 2003 | 09:45 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default window keeps falling off rail
my window keeps falling off the rail...how do i fix this...its not power window its manual...its a 96....do i just grease the rail or something along those lines??
Old Feb 16, 2003 | 09:50 PM
JSJ EG6's Avatar
Default Re: window keeps falling off rail (i've_got_the_ADVANtage)
mines do the same thing.anyone know how to fix it???
Old Feb 16, 2003 | 09:53 PM
aw1234dude's Avatar
Default Re: window keeps falling off rail (TEAM JSJ)
Yeah mine used to do the same thing. At first I thought i was just not aligned correctly so after a couple months of constant readjusting i ruled that out. I thought it also could've been a sticky rail problem but after lubing it still popped off. So i finally took it to honda and they charged me 200 bucks for parts and labor. I guess the rails were bent but yeah that was way too much and if i could do it again i wouldve just gone to a junkyard and picked up the entire assemble for probably less then 50 bucks.
Old Feb 16, 2003 | 09:58 PM
Hammett's Avatar
Default Re: window keeps falling off rail (aw1234dude)
just get a used bracket from the junk yard. Thats what I did.
Old Feb 16, 2003 | 09:59 PM
Resident Evo's Avatar
My friend has a 99 Si. He had the same problem too. So I told him to make a visit to a auto repair shop that were famliar with me. They fixed it in 5-10 min for free.
Old Feb 16, 2003 | 10:15 PM
Mikey's Avatar
Default Re: window keeps falling off rail (EBP-Si)
I had a similar problem. Every time I tried closing my window it wouldnt seal properly. I went out and bought a friggin new regulator thinking that was the problem. When I cracked open the door panel to replace the regulator I found that the rubber seal that lines the entire window was torn. So I went to the junkyard and paid another $5 for an easy fix. I have some pics somewhere if you want me to share.
Old Feb 16, 2003 | 10:23 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: window keeps falling off rail (Mikey)
lol...the first night it fell off...my friend was rolling down the window...he did it really roughly...and when i tried rolling it back up...it didnt go...it went maybe half way...then i got stuck...but it got stuck a lot...so i just let it chill...i got home...brother was *** drunk...tried to roll window up...and broke the handle... bastard.
Old Feb 16, 2003 | 10:24 PM
i HAVEtheADVANtage
Guest
Posts: n/a
and another thing...how come civics in my experience power locks or not wont lock when the door is open...is it just like that?
Old Feb 16, 2003 | 10:34 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: window keeps falling off rail (MagoDeOz)
its not just the power locks its the manual ones too
u can lock while the door is open if u pull the handle & the just lock it.
its weird
lol...yea i know...i said power locks or not...but why did honda do that?? i think its only the locks that have the flipping thing...and not the pulling thingie
Old Feb 16, 2003 | 11:48 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
its weird
Okay, tell me how many times have you locked yourself out of the car? That is why it is done this way to prevent you from locking yourself out of the car, you actually have to do more then graze the lock button to become locked out with that configuration.
Back to the topic on hand, I took a look at how the door window was rolling up and down, mind you this was with power windows though. Anyway, I noticed the bolt was sliding inside farther each time I would roll up the window. It is only a white plastic piece it is attached to with a nut and bolt on plastic so the bolt can only be tightened so much. I figured I could increase the contact area with a slightly larger headbolt, after doing so I tested it a few times to check if it was sliding. Haven't had any problems for 5-6 months at least.
Old Feb 17, 2003 | 04:51 AM
1 2 NV's Avatar
what yr cars do u guys have???? mine did that the other day for the first time. my cars a 99 EX.
Old Feb 17, 2003 | 11:23 AM
Vic Nyce's Avatar
my passenger side in my 96 2 dr keeps doing this too twice in a month. ive left the door panel out cuz its such a bitch especially in the cold
trooper0641
Dec 5, 2006 04:02 PM
99fbpem1
10
Aug 31, 2005 09:44 AM
98DC2teg
10
May 13, 2005 01:56 PM
dylokjai
Apr 6, 2005 02:18 AM
1hotintegra
Mar 3, 2003 07:20 PM
