Engine code on your CRX Si
Old Feb 16, 2003 | 08:50 PM
tdaccord's Avatar
Default Engine code on your CRX Si
hey all, why does my 1990 crx si have a 1500 engine on it? I was checking insurance quotes from Progressive, and it showed only the 1991 had the 1.6, is this true? all 88-90 crx Si's had a 1.5? any replies would be appreciated
Old Feb 16, 2003 | 08:52 PM
ZCcivic91's Avatar
Default Re: Engine code on your CRX Si (tdaccord)
uhhhhhhh I think mabey you got a problem, when did you get the car? And if its only a 1.5l it aint an si motor. Is it MPFI or DPFI? It will say on your intake manifold. Mabey someone replaced the motor before you got it with a dx motor. Or mabey even a hf?
Old Feb 16, 2003 | 08:55 PM
tdaccord's Avatar
Default Re: Engine code on your CRX Si (ZCcivic91)
its all gunked up there, so i don't know about the swapped issue. but on progressive insurance site, it only listed the 91 having the 1.6??
ohh yea, its mpfi
[Modified by tdaccord, 5:55 AM 2/17/2003]
Old Feb 16, 2003 | 09:47 PM
Redline130's Avatar
What is the engine code? A Si motor is a D16A6.
Old Feb 16, 2003 | 10:31 PM
ZCcivic91's Avatar
Default Re: Engine code on your CRX Si (Redline130)
from 88 - 91 all honda civic/crxs si models came with a 1.6l SOHC. It should be pretty simple to clean up the part where the code is if you know where to look. Try using Simple green to clean off the oil with a rag. if it says D16a youve got an si motor, if it say D15, youve got a dx, not sure what the HF motor code is, youd have to ask the one of the CRX guys, I dont know anything about that motor.
Basicly it sounds like progessive dosnt know better or just a typo on there site. There not right, we are.
[Modified by ZCcivic91, 11:33 PM 2/16/2003]
Old Feb 16, 2003 | 10:43 PM
slowman's Avatar
I took way too long
If it's MPFI, it's either HF or Si. If your valvecover says 8Valve Honda then youve got a 62HP HF. If it's 16Valve Honda, youve got 108HP Si.
Old Feb 16, 2003 | 11:20 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
i bought the car like this.. ::grin:: can you guys tell me what kind of motor i gots?
[Modified by Built B16A, 8:21 AM 2/17/2003]
Old Feb 17, 2003 | 04:35 AM
Hondasaurs's Avatar
Default Re: Engine code on your CRX Si (Built B16A)
Judging for the shape of the Block its a B series motor, and since your user nane is Built B16A, I'm going to safely assume its a B16
Old Feb 17, 2003 | 05:27 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Engine code on your CRX Si (ZC_CRX)
no take a picture of the engine and Ill tell you.
Blaze
Old Feb 17, 2003 | 05:52 AM
SOHC CRX GURL's Avatar
Default Re: Engine code on your CRX Si (Blaze45)
This sounds kind of fishy. But so you know the insurance shouldn't be that much different. Mine is only 130 every six months, and on my DX it was 125 bucks.
Old Feb 17, 2003 | 06:54 AM
crxgurlllll's Avatar
d16a6 = si
d15b6 = hf
d15b2 = dx
Old Feb 17, 2003 | 10:59 AM
Built B16A's Avatar
Heres that pic you wanted ZC_CRX...
[Modified by Built B16A, 8:00 PM 2/17/2003]
zrostr
Classic Hondas
Nov 10, 2009 05:09 PM
classciv
May 12, 2007 01:47 PM
Drian
Feb 4, 2004 08:00 PM
irishpilot
Feb 20, 2003 08:39 PM
infamousALLMTR
Jan 31, 2002 05:48 PM
