Catch can q along with PCV valve
http://www.tgilmore.com/talon/catchcan.html
Is this a logical idea for a catch can or a risky idea??
oh yeah bump
Thats accually the best Idea Ive seen in a while from a do it yourself'er. Yes that is a logical Idea you just need to change the catch can once in a while lol.
Ok so I remove the PCV valve and run a hose into this filter and out into the rear of my B18A block in to the black box where the PCV valve hose orginally went?? Is this correct?? Or do I leave my PCV valve run it into this?? I'm still kinda confused where it gets routed to. The return hose goes into the back of a B18A is this correct also?? TIA
leave the pcv valve alone. just place the filter between the hose that runs out of the valve cover and the air intake tube. All a catch can does is catch any acess oil that goes through that tube from going into the air intake.
Oh its only for the intake tube its not the same thing that runs into the back of the block correct. Just wondering because my Intake didn't have a PCV valve, guess gonna have to try to finagle the one out of my Y8 manifold then to replace it.
Thanks
Thanks
