whats the diff between USDM ITR 5 Lug and JDM CTR 5 Lug
whats the diff between USDM ITR 5 Lug and JDM CTR 5 Lug?? the CTR ones are easier to find, i know their both 32mm axles. any big diff between the two?? anyone know a place to get them?? cheap??
Same thing.
The only differences between the two would be the LCAs and shocks.
And most of the time, they don't even come with the setups.
No. They are different.
ITR won't work on 96-00 civic and vica versa.
If you have a 92-95 civic, CTR won't work...
fowler knows what he speaks though
word up, and the LCA's are designed differently, and therefor, also accept different shocks/struts/coilovers yada yada yada.
[Modified by jonas, 4:21 PM 2/16/2003]
i have an '99 hatch, so i am guessing it would be better for me to go with the JDM CTR 5 lug??
I'd go with the CTR's.
I had 5 lug from an Integra, and I'm pretty sure that Jonas has the same thing... I never had problems with compatiblity.. well, the ebrake cables had to be kinda of ghetto rigged to fix themselves to my chassis, but that's not really a big deal.. so, uh ITRs are no problem. CTR would be best... I'm starting to ramble..
the ITR LCAs are shorter and have a whole where the shock goes thru the arm and bolts in, the civic is longer(6gen) and the shocks have a u shaped where it rest above the arm. ITR will fit on an EG but not an EK.
Like I said before, most of the time, when you buy 5 lug, you don't even get the LCAs or the shocks, so, it doesn't really matter which you get.
jdmjohn02
Jan 12, 2004 12:03 AM
midnightdarknes5
Jun 2, 2003 10:08 PM
4doorturbo
Feb 16, 2003 04:51 PM
