Clutch pedal problems, no pedal pressure..help
Old Feb 16, 2003 | 01:56 PM
Flamenco-T's Avatar
Default Clutch pedal problems, no pedal pressure..help
LAst night for some strange reason, after a whole night of boosting, my clutch pedal dropped all the way to the floor board...
all the pedal pressure is gone and I wasn't able to get it in gear whatsoever...
I noticed the fluid on the master cyilinder were empty, so I fill it up with a new clutch fluid, pump the pedal a few times, still no pressure and the fluid is not moving within the cylinder..
today, I checkd the slave cylinder and the clutch fork, the throw out bearing is still there, no leakage at all from the lines, the slave cylinder is still operational..
I looked under the dash at the pedal, nothing is missing or loose, nothing is out of the ordinary,....no fluid leaks form the damper on the pedal...it drips a lil bit, but that's normal...but no sign of fluid puddle or anything..
still no pedal pressure and it will not get in gear
any suggestion ?
TIA
stan
Old Feb 16, 2003 | 03:58 PM
lunarcry's Avatar
Default Re: Clutch pedal problems, no pedal pressure..help (Flamenco-T)
maybe you have air on the line,you try bleed the clutch line .
blue_hatch
Apr 15, 2018 04:13 PM
S2Integra
Transmission & Drivetrain
Oct 18, 2011 08:28 AM
stock95civic
Mar 12, 2007 10:55 PM
Flamenco-T
Feb 16, 2003 06:38 PM
Flamenco-T
Feb 16, 2003 04:26 PM
