Ls/vtec turbo....again. don't reply if you tell me to use the search button
Old Feb 16, 2003 | 12:27 PM
Drkaccrd's Avatar
Default Ls/vtec turbo....again. don't reply if you tell me to use the search button
I have a 95 ex with an LS/Vtec getting ready to slap on a Rev hard stage 2C kit. Is there anyone out there that has this set-up and drives it daily with out too much trouble ?
Old Feb 16, 2003 | 01:52 PM
ridnmyhonda's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (Drkaccrd)
do a search it's been covered
Old Feb 16, 2003 | 01:55 PM
dmotoguy's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (ridnmyhonda)
"don't reply if you tell me to use the search button"
Old Feb 16, 2003 | 01:59 PM
Flamenco-T's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (dmotoguy)
not going to reply...
dude, LS/VTEC, LS, GS-R, is all the same, IT'S ALL IN YOU AND HOW YOU DRIVE..
you want a reliable motor, stay stock...
Old Feb 16, 2003 | 02:27 PM
bruthaboost's Avatar
see my sig
Old Feb 16, 2003 | 03:03 PM
V-SPEC 1's Avatar
_______
Old Feb 17, 2003 | 04:09 AM
Drkaccrd's Avatar
I have done the search. Again looking for members who OWN this setup and can give me their personal experience. Even if its N/A thats cool to, but really looking for the F/I members. That is unless you can point me to a thread that answers my question in particular. The discussions I found were THEORIZING about what could and could not work.....thats not what I asked.
Old Feb 17, 2003 | 04:20 AM
Drkaccrd's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (bruthaboost)
bruthaboost whats your setup for internals? Do you have a block gridle?
Old Feb 17, 2003 | 05:37 AM
Realtimeb18c1's Avatar
yo...Berto, you need to change your pic man! ha!
Old Feb 17, 2003 | 06:06 AM
My internals: nitride coated ss valves, r valve springs, ti retainers, eagle rods, wiseco pistons and see pics for the block girdle.
I had the mains machined and doweled.
installed
HTH
Old Feb 17, 2003 | 09:19 AM
PWRVTEC's Avatar
Well IMO, I think the LSVTEC's and CRVTEC's are just *** reliable as any other engine if built right. I have a bulit LSVTEC that has 1000 miles on it all motor, most of which has been 800 of hard miles. Had a little leaking from the head where it meets the block, did a retorque of the head studs and all gone.
I have bulit many LSVTEC/CRVTEC's for people and never had a problem.
It will turboed this week so I can give you some more reviews on that then.
Here are a few shots..
Old Feb 17, 2003 | 10:44 AM
AVATAR's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (PWRVTEC)
What did yo spray the block with? Looks good.
Old Feb 17, 2003 | 11:26 AM
B18EG6's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (AVATAR)
the block looks painted...but if you are asking to which paint, i dont know.
on the other hand, if you are referring to the gold hue on 'top' of the block, thats copper spray on the headgasket
Old Feb 17, 2003 | 12:00 PM
AVATAR's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (B18EG6)
The black block- is the color just black? What temp. ? Where can I buy some?
Old Feb 17, 2003 | 03:09 PM
lilxvtecxpwr's Avatar
thats one clean *** engine bay pwrvtec
Old Feb 17, 2003 | 03:18 PM
LsVTeCTuRBo17's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (lilxvtecxpwr)
Golden Eagle Sleeves, 9:1 comp. Looks Clean.
Old Feb 17, 2003 | 03:21 PM
I have some Revhard parts on my car (i.e. manifold) but a custom turbo kit. I had my block and machining done by JG. Have not had any problems yet. My suggestion is to you is if you are going for a lot of hp, build the motor, don't do it half-assed. If you want reliability just boost at 9 psi all day with no problems.
Old Feb 17, 2003 | 09:23 PM
PWRVTEC's Avatar
AVATAR
The paint is 500 degree Dupli-color. And AVATAR has a PM on my secret on how to keep it on there.
B18EG6
Yep thats copper spray, I just wish I could get the block that color...that would be cool... Ok so I am a ricer...
lilxvtecxpwr
Thanks dude... It took a bit of cleaning and painting but overall I am happy for only a day of work.
LsVTeCTuRBo17
Yep Yep Well really its 9.6 with the shaved head, valves that I used, head gasket thickness and opened combustion chambers. But the pistons are 9.1 for sure, Endyn specials...
Old Feb 17, 2003 | 09:29 PM
giooooo's Avatar
is your bore still 81mm? how much are those endyn pistons?n im think int your bore is 84 mm..? cuz when i went to save one of your pics the name of the pic said "ls84" so i figured it out lol nice engine bay
[Modified by Giovannie, 6:31 AM 2/18/2003]
Old Feb 17, 2003 | 09:37 PM
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (Giovannie)
What kind of valves are on the head? what size?
Old Feb 17, 2003 | 09:59 PM
PWRVTEC's Avatar
No the bore is 84.5mm.... Thanks for the props on the engine bay... I will post the finally ones when I finis putting the turbo on this week.
The valves are made by Manley and they are custom dome valves. Instead of flat or dish they have a slight dome to them, which is supose to smooth the incoming charge out, and help direct exhaust out. And rasie compression..
The sizes are 1mm oversized on the exhaust and .5mm on intake.
[Modified by PWRVTEC, 2:00 AM 2/18/2003]
Old Feb 22, 2003 | 08:43 PM
Drkaccrd's Avatar
pwrvtec keep me posted when you boost on your ls/vtec motor give me pics and numbers if you have'em.
Old Feb 22, 2003 | 09:31 PM
TurboInteg95's Avatar
Default Re: Ls/vtec turbo....again. don't reply if you tell me to use the search button (Flamenco-T)
Im with you.
Old Feb 23, 2003 | 01:08 PM
PWRVTEC's Avatar
No Problem
Old Feb 24, 2003 | 06:55 AM
dabrown's Avatar
I am interested in finding out as well. Unfourtanetly I have a bug for Turbo and when I bought my car it had a LS/Vtec High Compression setup already. I don't want to rebuild so I am looking to go custom turbo for price reasons. I will only attempt to do 5-6 Psi due to the compression. So I guess it would probably be best to look at what the Type R Turbos are doing since they have the High Compression stock.
