B18b throttle body on my 1st gen b16a
Old Feb 16, 2003 | 10:53 AM
Rywire's Avatar
Default B18b throttle body on my 1st gen b16a
I just won a 97 b18b complete throttel body, and sensors on ebay. I was sick of my throtel body sticking (allready cleaned) and I think my throtel position sensor is also bad. Also, it is a upgrade or 2mm over stock 58mm. Will this be a straight bolt on? I assume so. What gasket do I get? 94 del sol vtec? Thanks for the replys in advance. Ryan
Old Feb 16, 2003 | 11:14 AM
rioninja's Avatar
Default Re: B18b throttle body on my 1st gen b16a (droppedcrxsi)
yes, it will bolt right on. BUT, since its 97 tb it will have a map sensor mounted directly to it, instead of on the firewall. All you need to do is extend your map sensor plug wires so that it reaches the map on your new TB.
Old Feb 16, 2003 | 09:03 PM
Rywire's Avatar
Default Re: B18b throttle body on my 1st gen b16a (Rioninja)
ok, so on the b16a t-body theres a throtel position sensor on the bottom , and another sensor on the back(what is this), any there will be a third sensor on the b18b? So there is 3 on a b18b, and 2 on a b16a. Is my map sensor the 3 wire plug on the fire wall? I hope you understand. Thanks, Ryan
bimmeracer
Nov 6, 2007 11:41 AM
SuicideSlide
May 16, 2005 01:47 PM
DXK Eg
Feb 11, 2005 05:05 AM
barry11j
Jul 7, 2004 02:05 PM
Rywire
Feb 24, 2003 08:55 PM
