skunk2 camber kits for eg fit ef??
Old Feb 16, 2003 | 10:44 AM
PhatHardy's Avatar
Default skunk2 camber kits for eg fit ef??
I was just wondering will the camber kit from skunk2 from an eg fit on an ef? I mean don't they have basically the same suspension? I'd really like to get these, but i'm wondering why skunk2 doesn't say they will fit the 88-91 as well? Could anybody answer this question?
Old Jul 15, 2003 | 08:59 PM
CRXTSEE's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (PhatHardy)
bump... for the same question
Old Jul 16, 2003 | 02:13 AM
markleavey's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (CRXTSEE)
This is something I would like to know as well. Can anybody help?
Mark
Old Jul 16, 2003 | 05:30 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: skunk2 camber kits for eg fit ef?? (markleavey)
the Skunk2 camber kit, only lists for aplication for 92-95 civic, and 96 and up tegs.. if it was for EF's.. it would spesify.. however, the Ingals, and i know for a fact, Progress (i have them) makes them for the EF. i belive 2 years ago, i paid 1 bill cash on the progress kit.
another thing.. the 92-95 upper controll arm (A Arm) looks the same.. but like i siad.. if Skunk2 wanted it to fit everything, they would of advertived for it. they're are other kits out there..
Old Jul 16, 2003 | 09:09 AM
B16CRXSi's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (Built B16A)
There are other kits out there but most of them aren't the A-arm. I have only found one kit that includes the A-arm. It is a vision kit from Japan. It cost $320 for the set!
Old Jul 16, 2003 | 09:18 AM
jc836's Avatar
FAct is that the 88-91 Upper ControlArms are NOt the same as the 92-95. Honda made a detail change in the spacing for the bushings.
Old Jul 16, 2003 | 09:21 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: skunk2 camber kits for eg fit ef?? (jc836)
SPC makes offset balljoint kits for ED.
also, FYI, i am using integra's UCA on my rex, i had to cut the bushing braket in half to space them correctly
Stan
Old Jul 16, 2003 | 10:12 AM
CRXTSEE's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (90crxsi)
anyone use the offset balljoint?
Old Jul 16, 2003 | 01:01 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXTSEE &raquo;</TD></TR><TR><TD CLASS="quote">anyone use the offset balljoint?</TD></TR></TABLE>
ball joint.. or the bushing part that holds the a arm to the upper fender?
the progress kit i have, was like.. 4 knuckels.. basicly, you install the stud on the new bushing, for how many degrees you want corrective camber. i can't move my ball joint around.
Old Jul 16, 2003 | 03:24 PM
Outsane's Avatar
Adjustable ball joints..
I have had them..
I loved them..but I had to put holes in the shock towers for clearance.. only drawback..
Old Jul 16, 2003 | 03:58 PM
ExospeedAMcrx's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (Outsane)
yes, the only camber adjustment kits for the EF are the SPC ones. They are the best available out there. What other company makes suspension kits for almost everysingle US market vehicle out there? SPC #1
Old Jul 16, 2003 | 04:53 PM
Outsane's Avatar
Default Re: skunk2 camber kits for eg fit ef?? (exospeedAMcrx)
Eibach sells kits too.. they are made by SPC.
Ingals sells front camber kits.
Progress makes a kit...
and Tien has upper pillow mounts..
Old Jul 16, 2003 | 04:54 PM
ncrx1's Avatar
A-Sports of Japan makes a camber/castor adjustable a-arm. But it costs an arm... relative to the others...
highmilehatch
Dec 4, 2008 05:01 PM
Jedi Jake
Apr 19, 2007 07:13 PM
auburnBoy
Dec 19, 2004 02:24 PM
crx91-sir1
16
Jan 14, 2003 08:29 AM
