Timing Belt
Old Feb 16, 2003 | 04:25 AM
cbamishere's Avatar
Default Timing Belt
I recently had my timing belt changed and I have noticed that the engine seems to be louder then normal has anyone run into this problem ?
Old Feb 16, 2003 | 04:47 PM
jdowen2's Avatar
Default Re: Timing Belt (cbamishere)
If you're talking about a buzzing vibration it could be that the balance shafts were not at their top dead center when the balance shaft belt was replaced.
Old Feb 16, 2003 | 10:02 PM
Okley_01's Avatar
The one thing that will make it a lot louder is if you leave the timming belt cover off. Also, if you had a belt installed that was from checker, that could easily be your problem. The quality of timming belts makes a huge difference. Or, it might not even be your timming belt. Exactly what kind of noise is it making? If its more of an Harmonic noise, then its most likely the belt. Also, if its just a little bit louder, then dont even worry about it. Once it breaks in, it will get a little quieter.
Old Feb 17, 2003 | 03:30 AM
CardDealer's Avatar
Banned
Default Re: Timing Belt (Okley_01)
Modified by CardDealer at 4:06 PM 11/17/2006
Old Feb 17, 2003 | 08:26 AM
Okley_01's Avatar
Default Re: Timing Belt (schlit)
Good deal on the blelt. Glad to hear it was a simple fix . Btw, excuse me with the whole break-in process. What i ment to say was that in some cases, the timming belt noise will go down slightly after the first few hours of use.
killsnake562
Mar 31, 2009 03:55 AM
Osis
Honda Civic (2001 - 2005)
Oct 15, 2007 08:23 AM
obd2gsr
Dec 21, 2002 08:53 PM
$300lude
Dec 15, 2002 09:25 PM
nerdish
Jul 17, 2001 11:22 PM
