After cam install car won't start.. any pointers?
Guest
Posts: n/a
Hey, I put in type r cams into my car today and now the car won't start.. I'm gonna tear it all apart and do it again tommorrow, but I was just wondering if you guys had any pointers for putting them in the next time around? I'm almost 100% positive it was at tdc so.. not quite sure what I did wrong, but if that were the case wouldn't it still start, but just act really funny?
Thanks guys
[Modified by Jay Hovah, 1:02 AM 2/16/2003]
Thanks guys
will it still crank? even if you're off by 1mm or 2, it'll still turn over. spark plugs wires in the proper firing order?
Guest
Posts: n/a
I checked the spark plugs like 5 times because I figured that might be the problem. But they all seem to be fine. When I put the key in the ignition (and turn it) it sounds like things are moving and the exhaust makes this tiny little noise, but it just doesn't start. Btw- I know it's hard to figure out a problem like this when you can't see it, so thanks for helping out I appreciate it.
[Modified by Jay Hovah, 1:39 AM 2/16/2003]
i had the same problem after i put my cams in. turns out i put the distributor on 180 out of time
. you should do a valve adjustment before you start it.
bonestock92si
38
Aug 30, 2004 10:02 PM
