underdrive Pulley
Old Feb 15, 2003 | 09:35 PM
accord ex's Avatar
Default underdrive Pulley
Sorry for the newbie question guys, but where does an underdrive Pulley goes, and whats the point of it? Thanks for all the help, and again im soooory for the newbie question, it sucks being a newbie .
Old Feb 15, 2003 | 11:58 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: underdrive Pulley (accord ex)
hmm...underdrive pulleys They are the circular devices that are on your accessories IE -- AC PS alt
there is also the main one that comes from the engine and spins all of the others but it is NOT reccomended that you replace that one because of balancing or something...someone else explain the phenomenom
[Modified by tharptroy, 9:00 AM 2/16/2003]
Old Feb 16, 2003 | 04:01 AM
sauceman's Avatar
Default Re: underdrive Pulley (tharptroy)
Right. About the problems you might encounter with a crank pulley, check out this thread: https://honda-tech.com/zerothread?id=319189
As for the accessory pulleys, they are generally machines from billet aluminum. They are supposed to be at least twice as light as the OEM pulleys. They will also underdrive, meaning that because of their larger diameter (as much as 30% i think), the accessories pulleys will not rotate as quickly, so their is less drag on the engine.
AEM accessory pulleys, for example, claim to have 5.5hp, and 8lbft gains on an F22B1. While I cannot tell you it is the power gain of the year, it does help the engine do happier revs.
The slower rotating pulleys won't cause you to have less voltage on your electrical system, nor will the PS be affected either. Personally, if you have a totally stock car, and you don't want to do any modifications with any downside (comfort, noise, fuel economy, reliability), this is one of the rare mods to be done, and I believe it will be the one that will yield you the most "power".
Hope it helps,
Jeff
PFCAcosta
Jan 28, 2011 05:08 AM
remoer
16
Jul 2, 2008 10:30 AM
spyderracing
Aug 16, 2004 04:34 AM
Luiyo
May 1, 2004 08:38 AM
vtec69
Nov 1, 2002 01:18 PM
