block building question please answer
ok i have a bare block, and by bare i mean pistons rods, crank and block, all disassembled....
im buying the following i want to know if this is all i need in order to slap the head on and drive:
block is a LSvtec b18b (1999)
oil pump and pick up,
timing belt,
timing tensioner
intake and exhaust manifold gaskets
water pump
2 thrust washers
rear main seal
rear main seal retainer
5 upper and 5 lower main bearings
8 rod bearings
head gasket
i need all hardware (bolts)
..... my question is to finish the block what else do i need.... i have the following tell me if i cant use any of the following:
fidansa flywheel
act clutch
b16a oil pan
flywheel plate off b16a
oil squirters off b16a
oil plate that goes under crank (i forgot name) off b16a
lsvtec oil line
b16 head drilled and tapped for ls vtec
what else do i need, with LS block will the b16a oil pan be enough or not
thx in advance
timing belt,
timing tensioner
water pump
2 thrust washers
rear main seal
8 rod bearings
head gasket
fidansa flywheel
act clutch
b16a oil pan
lsvtec oil line
thx in advance
SilverStreak02
May 19, 2009 06:25 PM
