No power steering - no manual steering rack
Old Feb 15, 2003 | 05:13 PM
all stock's Avatar
Default No power steering - no manual steering rack
do i HAVE to convert to a manual steering rack? Personally, I can deal with the bitch of parallel parking and pushing around the fluid. But someone on this forum said that having no P/S will eventually screw up my rack and i have to replace it to manual. is this true? what does built pressure do in terms of ruining my steering? so i can't just remove all my p/s components and drive like that forever?
yes, i did a search, 6 pages of power steering...i read thru most of them.
Old Feb 15, 2003 | 05:23 PM
JwM's Avatar
JwM
Default Re: No power steering - no manual steering rack (all stock)
This thread in particular should offer some help https://honda-tech.com/zerothread?id=184202
EK MONEY's Avatar
you can actually loop the fluide, all you do, is run a line back to the rack from the container. all you really have to do is keep the rack wet.
Old Feb 15, 2003 | 05:27 PM
all stock's Avatar
Default Re: No power steering - no manual steering rack (Peagreenhatch)
i've seen that thread. that's for conversion.
i want to know if i HAVE to loop stuff? can't i just leave it alone?
Old Feb 15, 2003 | 05:32 PM
JwM's Avatar
JwM
No that thread is an explanation on looping a P/S rack.... And it is recommended to loop the line for several reasons... One being it will be a little easier to drive, and two being it keeps the rack lubricated so that you avoid damaging the rack...
Old Feb 15, 2003 | 05:46 PM
Westrock2000's Avatar
Default Re: No power steering - no manual steering rack (MayonakaNinja)
well i've had the belt disconnected for about 8 months and havent had bad side effects. Still want to loop it, to get rid of all the crap in the bay.
Old Feb 16, 2003 | 12:04 AM
all stock's Avatar
Default Re: No power steering - no manual steering rack (Westrock2000)
do you DD that 8 month no power steering car? i picked up my car as a rolling shell w/o ac or P/S. i dunno how long it's been but i drive totally fine w/o it. i think it's been about 18 months or so. however, about 8 of those months were it - as a rolling shell. heh.
Old Feb 16, 2003 | 12:13 AM
elwood's Avatar
Does it have the fluid resivor? Or is it taken off all
the way to the rack? If you want to get rid of the
resivor and all the lines you can block the hole with a
bolt and use a peice of line with a breater on it or conect
the two with a slit in the line so that the presure does not
build up.
Old Feb 16, 2003 | 12:55 AM
all stock's Avatar
Default Re: No power steering - no manual steering rack (d15dude)
the resevoir's still there. because there is no belt, that means it's not circulating right? i have an EK and i wanted to know how far can i remove all this stuff to? the pump? the pump is near the middle part of the firewall, right? near the chasis? it's night so i can't take a picture...and my camera sucks.
i can just unbolt the resevoir, pull the rubber hose, and like you said, plug the hole? what happens if pressure builds up? i mean, hasn't it already been building up? how far can i remove stuff? TIA
Old Feb 16, 2003 | 01:14 AM
JwM's Avatar
JwM
you can remove the pump, the reservoir and then loop the line going to and from the rack itself... Add a breather in between the two, or something along those lines to allow air... All you are needing to do is keep a small amount of fluid in the rack to lubricate it... (also I promise you that link I gave you earlier is an explanation on how to do this...)
Old Feb 16, 2003 | 08:54 AM
delslow94's Avatar
does anyone know the threading and size of the fitting that you need for the rack. there have been around 2-3 of these how-to's but none say the fitting size, they only state the part number for aeoquip. we have a lot of good places around me for fittings thats why im asking. thanks
Old Feb 16, 2003 | 09:41 AM
qcoffey's Avatar
That link is awesome. The guy gives part number and the whole nine. I will definitely be doing this by the summer time.
Old Feb 16, 2003 | 10:40 AM
slammed_93_hatch's Avatar
Default Re: No power steering - no manual steering rack (qcoffey)
PS suck my car came with out and im sure glad it did were talking about a 2500 car maxs here guys if you can't handle that then i dunno
Old Feb 16, 2003 | 03:23 PM
vladd's Avatar
hey, i have a manual steering rack out of my 97 hatch for sale, it'll fit all 96-00 civic's. want it? you won't have to worry about all that looping **** .
Old Feb 16, 2003 | 03:33 PM
all stock's Avatar
Default Re: No power steering - no manual steering rack (civicdxtyper)
i just want to know if it's okay to remove the pump, hardlines and resevoir and drive without it. i don't care if i have to push the fluid myself.
Old Feb 18, 2003 | 12:32 AM
all stock's Avatar
so i don't need to buy anything right? i thought i would need an adaptor...
gotenz90640
Mar 19, 2016 03:57 PM
bizzle2288
Aug 27, 2012 05:29 PM
TurboEK9Coupe
Sep 28, 2008 04:29 PM
FrankencrxBHAM
Mar 2, 2007 10:50 PM
aeolus
May 11, 2003 11:03 AM
