how do they measure...???
Old Feb 15, 2003 | 03:25 PM
sslude's Avatar
Default how do they measure...???
when they say a car has 250BHP (brake horse power) how do they measure it? like how did they get 250 from the brakes? thanks
Old Feb 16, 2003 | 10:45 AM
JimBlake's Avatar
Default Re: how do they measure...??? (sslude)
They're not talking about the vehicle brakes.
An engine dynamometer lets the engine run, but instead of being hooked up to a transmission, the crank/flywheel is hooked up to a brake. That way the throttle can be wide open, & the brake controls the speed. Then it measures the torque and rpm & calculates HP from that. "Back in the day" (huh?) it was a friction brake, held in saddle bearings. Had a lever so you could pile weights on like a beam balance. Called a "Prony brake", I think. Now they probably use viscous or eddy-current brakes with load cells to measure torque.
CooBlueDAB
Oct 15, 2004 01:43 PM
Nocturnal
Nov 29, 2003 02:22 PM
SiR HatchAlot
21
Nov 28, 2003 05:53 PM
91civ
10
Jul 25, 2002 12:08 PM
