HELP NOW!! skunk2 mani ?
Old Feb 15, 2003 | 02:34 PM
cjames235's Avatar
Default HELP NOW!! skunk2 mani ?
we put a mani on a 98 gsr and now it hardly runs and blows black and white smoke out the exhaust along with black liquid. the idle is very irratic and if you give it any gas it dies. the plugs are also very black and they werent like that before they were perfectly clean. we have checked for all kinds of vacuum leaks and none are present. any help is greatly appreciated. it also has no codes
Old Feb 15, 2003 | 02:39 PM
au-gsr's Avatar
Default Re: HELP NOW!! skunk2 mani ? (cjames235)
did you reuse the oem gasket for the manifold? if so that would be one place to start looking
Old Feb 15, 2003 | 02:50 PM
cjames235's Avatar
Default Re: HELP NOW!! skunk2 mani ? (au-gsr)
no all new gaskets no leaks...
Old Feb 15, 2003 | 03:48 PM
ragejed's Avatar
injectors? running rich? get a b&m fuel gauge..see how that looks..I dunno..its a shot in the dark..
Old Feb 15, 2003 | 05:01 PM
au-gsr's Avatar
Default Re: HELP NOW!! skunk2 mani ? (ragejed)
did you put anything else on at th esame time as the manifold?
[Modified by au-gsr, 7:02 PM 2/15/2003]
Old Feb 15, 2003 | 05:19 PM
memphiss13's Avatar
fixed it we mixed up the two common mix up plugs on the throttle body.
Old Feb 15, 2003 | 05:21 PM
youngvedder's Avatar
i did the same thing..such a releif when you fix it...what do you guys think of the mani? happy with it?
cheers,
YV
Old Feb 15, 2003 | 06:15 PM
Halo's Avatar
there is a tiny nipple on the drivers side on the back...does that connect to the evap canister? Also on the head iteself(96 gsr) distributor side there are 2 coolant lines that come off the head..one goes to the thermo, then there is a smaller one right next to it...where does that connect to? Thanks
Old Feb 15, 2003 | 07:13 PM
B00ST2nR's Avatar
I ordered mine and an ITR AEM CAI also, since the GS-R CAI will not fit.
How you guys like the Skunk2 Intake Manifold?
Old Feb 16, 2003 | 06:31 AM
memphiss13's Avatar
Default Re: HELP NOW!! skunk2 mani ? (Skunk2nR)
yeah the guy we were putting it on for got the ITR CAI too. he likes the manifold. now he just needs to get some new o-rings for his injectors. leaking
Old Feb 16, 2003 | 07:49 AM
cjames235's Avatar
Default Re: HELP NOW!! skunk2 mani ? (rookie2nr)
yeah we spent the whole day trying to figure it out. worst day ever. but you can actually hear vtec now
elliott_219
Engine Management and Tuning
Aug 21, 2010 12:31 PM
B16Jacques
Jun 19, 2005 10:50 PM
cjames235
Feb 17, 2003 01:49 PM
cjames235
Feb 16, 2003 10:02 AM
JDMkings
Oct 15, 2002 04:32 AM
