Whats the safest boost for a Z6 intercooled.
Old Feb 15, 2003 | 02:33 PM
I Gotta Question's Avatar
Default Whats the safest boost for a Z6 intercooled.
Like above I just want to know what the safest psi for a Z6?
Old Feb 15, 2003 | 02:37 PM
turbod16y8's Avatar
Default Re: Whats the safest boost for a Z6 intercooled. (89_CRX_HF)
what kind of fuel management are you gonna run? with 12:1 fmu and a fuel pump then 8 psi is the max. With smc+ and 450cc injectors 12psi safely. with VAFC hack and 450cc injectors 12safely.
Old Feb 15, 2003 | 02:44 PM
camp1320.com's Avatar
I have seen 12-14 psi on a greddy kit with headgasket on stock motor. but if you gonna be running a bigger kit or custom kit ?? those damn stock cast piston ring glands are like brittle plastic just cracks off.
Old Feb 15, 2003 | 02:51 PM
Default Re: Whats the safest boost for a Z6 intercooled. (camp1320.com)
I was gonna use the 92-95 greddy kit and run it with an intercooler I think they have a piggy for my p28 that comes with it right.
Old Feb 15, 2003 | 02:54 PM
yes they have the greddy black box or blue box.. what ever its called.! it is a nice street unit for a lil extra Hp. just get a fuel system upgrade like a intank pump and hopefully all goes well..!
Old Feb 15, 2003 | 03:26 PM
Hybrid's Avatar
26psi with 2000cc injectors and a DSM ecu.
search, search and search again. This topi comes up almost every day.
No matter what internals you have, your turbo setup is alway's based on your fuel management.............................its your # 1 limiting factor. Just because you spent $3000 on parts don't mean that excessive lean conditions won't melt the **** out of things.
When I blew my motor the summer past (poor fuel management) I also did some heat damage to my head. I diden't realize this until I blew the new HG after the rebuild and took the head off and examined it.
Just remember, playing with a turbo is like playing with fire if you don't know what it can do.
Old Feb 15, 2003 | 03:50 PM
Default Re: Whats the safest boost for a Z6 intercooled. (Hybrid)
How much boost could I get out Of a greddy with the piggy and some 2000cc injectors and a high flow fuel pump?Safely
Old Feb 15, 2003 | 03:57 PM
tegasaurus's Avatar
he was joking (i hope).
scratch the greddy piggy back... get some dsm 450s and an SMC, you'll be set for 10 psi
Old Feb 15, 2003 | 04:26 PM
Default Re: Whats the safest boost for a Z6 intercooled. (tegasaurus)
Well a friend of mine runs 9psi not intercooled with the stock injectors and the piggyback.Sorry don't know much about injectors and aftermarket ecus. What is DSM and SMC.
[Modified by 89_CRX_HF, 1:28 AM 2/16/2003]
Old Feb 15, 2003 | 07:24 PM
Pengo's Avatar
damn is your friend running maxing out his injector duty cycle?
im currently running stock block w/greddy kit, dsm smic, dsm 1g bov, rc 310s, aem fpr, walbro 255 intank. i'm on 7psi daily rite now. once i get my new plugs and retard the ignition timing a bit im confident i could safely run 8. i've hit like 10 by accident before but i got off of it right away. as long as you dont get crazy and take care of your fuel u should be okay. having a motor thats in good shape doesnt hurt either
Old Feb 15, 2003 | 09:22 PM
rOby's Avatar
Default Re: Whats the safest boost for a Z6 intercooled. (Pengo)
a dsm is an old mitsu , diamond star motors...the have 450 cc injectors u can use.
smc is a program that a hondatecher named zip made to control the fuel ...
hahah when u run 2000cc injectors,call me up and let me know how i t goes?
Old Feb 15, 2003 | 09:57 PM
Drew Peacock's Avatar
Default Re: Whats the safest boost for a Z6 intercooled. (rOby)
Why don't people just answer the question, I can see the need for questions about engine management but come on, safely 8psi for every day driving of coure well tuned, you can take it up t0 12psi or about 220whp but do it only when needed and make sure its well tuned..
Old Feb 16, 2003 | 11:37 AM
Default Re: Whats the safest boost for a Z6 intercooled. (turbozxi)
Thanks alot for being straight on. I let you know how it works out for me.
Old Feb 16, 2003 | 02:24 PM
hybrid901's Avatar
a friend ran 12psi daily with a nos 255lph pump, rc 310's, and a 8:1 fmu
[Modified by hybrid901, 11:25 PM 2/16/2003]
red_hatchback
Sep 7, 2005 04:39 AM
Bimmerman
May 3, 2005 05:51 PM
boostincoupe
May 28, 2003 09:02 AM
Infinity_Racer
Mar 7, 2003 03:15 AM
00 Si
Nov 1, 2001 09:10 PM
