Hot do you improve a b16's accel or torque?
Old Feb 15, 2003 | 02:08 PM
SiKDeLSoL's Avatar
Default Hot do you improve a b16's accel or torque?
Hey, im just wondering what you guys would reccomend to improve a b16a1's acceleration or torque, what modifications have worked for you?
Old Feb 15, 2003 | 02:25 PM
OC 335i's Avatar
Default Re: Hot do you improve a b16's accel or torque? (SiKDeLSoL)
B18 block.
Old Feb 15, 2003 | 03:57 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Hot do you improve a b16's accel or torque? (MEGA EK)
what are you goals? ask your self that. Now, turbo, juice cams pistions.
Now decicde how much $$$ you wanna spend,
Blaze
Old Feb 15, 2003 | 04:09 PM
STHPERFORMANCE's Avatar
Default Re: Hot do you improve a b16's accel or torque? (Blaze45)
b16a + 84mm or 87mm sleeves with some 12.5:1 compression pistons.....
OR
B16a + 87mm sleeves with 9:1 compression pistons and a 60-1/t3 with a 2-step
Either or would do the trick,,, turbo would be the better way of going
Old Feb 15, 2003 | 04:28 PM
sslude's Avatar
Default Re: Hot do you improve a b16's accel or torque? (Outkast)
re-sleeve/bore, high compression pistons, light-weight rods, cams, I/H/E, pulleys, P&P, flywheel, and clutch, that should get you noticalby faster. there is no replacement for displacement
Old Feb 15, 2003 | 04:33 PM
altoid's Avatar
Default Re: Hot do you improve a b16's accel or torque? (sslude)
except for honda
Old Feb 15, 2003 | 05:06 PM
91DA9's Avatar
replacement for displacment
seigisama
Engine Machining & Assembly
Aug 5, 2016 03:47 AM
kart_driver
26
Aug 31, 2010 01:07 PM
sick93sol
Apr 10, 2009 08:00 AM
lsturbo*
Sep 16, 2006 05:24 PM
StinkyTofu
Oct 22, 2001 09:30 PM
