maximum tires on stock Integra fenders
Old Feb 15, 2003 | 01:20 PM
boosted3g's Avatar
Default maximum tires on stock Integra fenders
After calculating my gear ratios with my power i have come to realize there is no way my 24.5 slicks are gonna cut it unless i get rid of my Y21 trans. i dont want to get rid of the trans so my next logical step is to increase tire diameter. My problem is that i want to keep my factory fenders. I absolutly dont want to deal with a fiberglass front end. Is there any way i can run 26 x 8's or 8.5's under the stock sheetmetal. I am thinking it wont but what do you guys think about actually cutting the fenders. Is this pathetic or has anyone thought of this? Function before form i guess.
Old Feb 15, 2003 | 02:08 PM
jinxproof99's Avatar
New User
Default Re: maximum tires on stock Integra fenders (boosted3g)
trim the fender. you probably will get the 25" under them but not a 26". just do alittle trimming and be careful.
*trimming your fender will not be legal in the NHRA street class(for those that care.)
Old Feb 15, 2003 | 02:10 PM
boosted3g's Avatar
Default Re: maximum tires on stock Integra fenders (jinxproof99)
thanks Jinx, so you think no chance i can get 26's in there. What if i mess with backspacing, im planning on buying a set of Bogarts and i havent placed the order yet.
I dont think ill pass for street so im cool with trimming fenders
[Modified by boosted3g, 6:11 PM 2/15/2003]
Old Feb 15, 2003 | 02:51 PM
newspeedR's Avatar
you can also cut the factory fenders and add on fender flares to get the extra clearance and also to help enclose the slick from out side exposure...
Old Feb 15, 2003 | 06:06 PM
hondaswaper's Avatar
Default Re: maximum tires on stock Integra fenders (newspeedR)
we ran 26s for awhile with un cut fenders , but the car was riding mafia style (front much higher than the back)
Old Feb 15, 2003 | 07:40 PM
littlebluecrx's Avatar
We fit 25's on a third gen integra no prob, 26's will fit by trimming the fenders. Hell I fit 25's on my crx with out cutting the fenders. Jason
Old Feb 15, 2003 | 09:48 PM
paulzy's Avatar
Default Re: maximum tires on stock Integra fenders (littlebluecrx)
Mike at Motormatrix fit 28x10 under the stock fenders in there race car. I'm not sure how they did it, but you can IM him
Old Feb 16, 2003 | 04:39 AM
boosted3g's Avatar
Default Re: maximum tires on stock Integra fenders (Paul_Vang)
JAson you might remember this car, i messed around a few times at Cecil with it and i remember seing you there. I remember one even when you qualified first and i was 2nd then it got rained out like 2 years ago.
Thanks for the help guys but i have one more questions. What backspacing would you use to fit them in there. I was thinking like a 5" backspace but others are available.
Old Feb 17, 2003 | 03:41 PM
turbotypeR@SPEC's Avatar
25 Year Member
i have been contemplating using 26"(goodyears) as well.the only thing is,i am going to have to borrow them to try unless someone says yeah,they will work.to the people that have used them, did you have any serious rub and what offset wheels did you use?i have 15" bogarts with alot of backspacing so i really don't think they will work.
Old Feb 18, 2003 | 11:36 AM
H25's Avatar
H25
Default Re: maximum tires on stock Integra fenders (turbotypeR)
my 95 gsr ran 26s on stock uncut fenders it ran fine. yes a little on the high side up front but it still worked.
Old Feb 18, 2003 | 11:41 AM
boosted3g's Avatar
Default Re: maximum tires on stock Integra fenders (LuckyRacing)
Luckyracing- do you know what size wheels and what offset you have?
Old Feb 19, 2003 | 08:03 PM
miller's Avatar
we have a set of 26"'s on an ek at the shop and the fender has to be trimmed. im doubt the integra has that much more room..
Old Feb 22, 2003 | 12:33 PM
H25's Avatar
H25
i ran the bogart pro 4 15x8.5. as far as backspacing it came with a welded on spacer. it took forever for those things to come in. you cant run the car slammed . you gotta raise it up . but mine cleared just fine even at big end 140mph plus with tire growth it seemed to be ok. but i have my suspesnsion dialed in perfect so that always helps. ive seen people with 26s that rub the tires during breaking after making a run. its all how you set the car up. good luck
Old Feb 22, 2003 | 04:19 PM
miller's Avatar
i want to put 30's on my car
Old Feb 23, 2003 | 07:41 PM
integra6650's Avatar
Default Re: maximum tires on stock Integra fenders (vtecdoc)
so what we're saying is 26 with eibach sports wouldn't work if not how much is is to roll the fender
one more ? on gsr hubs will bogart 13X9 fit
Old Mar 10, 2003 | 05:11 PM
boosted3g's Avatar
Default Re: maximum tires on stock Integra fenders (integra6650)
Well i jsut ordered a set of front and rear bogarts with 26 inch Goodyears for the front. Ill let you guys know how they fit. Hopefully they with fit under the sheelmetal with out the use of shears.
BTW Exospeed has kick *** pricing for Goodyears and Bogarts.
aleks77
Paint and Body
10
Apr 27, 2007 11:43 PM
04RioS2k
Honda S2000
Feb 25, 2005 08:08 AM
Suprdave
Jan 22, 2004 01:55 PM
karmannghia
Aug 1, 2003 03:19 PM
greebler
Dec 16, 2002 11:57 PM
