Removing O2 Sensor
Old Feb 15, 2003 | 12:31 PM
steve_s's Avatar
Default Removing O2 Sensor
I want to take the heat sheild on my header off.
How do I take the o2 senser off it. Do I just yank it off?
Old Feb 15, 2003 | 12:43 PM
JDMH22HATCH's Avatar
Default Re: Removing O2 Sensor (steve_s)
Un-screw it with an open end wrench, or unplug the harness, take the cat off, take of heat shields, bolt cat back up, and plug in harness.
Old Feb 15, 2003 | 12:45 PM
tominos's Avatar
yank it? wtf, if you look at it, its pretty self explanatory. use a crescent wrench or open end wrench.
Old Feb 15, 2003 | 01:08 PM
pennies_hatchie's Avatar
Default Re: Removing O2 Sensor (tominos)
use a wrench
Old Feb 15, 2003 | 01:31 PM
steve_s's Avatar
Default Re: Removing O2 Sensor (pennies_hatchie)
I just unclipped the harness. Took a second then put it back in.
I dont need the heat sheild right???
What is the purpose for it in the first place?
Old Feb 15, 2003 | 01:40 PM
slvrcivic97's Avatar
I think I will take mine off too. Just a warning though, the headers are really fugly from what I've seen.
Old Feb 15, 2003 | 01:42 PM
steve_s's Avatar
Default Re: Removing O2 Sensor (slvrcivic97)
Yea they are, but I like it better anyways.
Just a bit of warning, the bolts can be pretty tight and i slammed on my wrentch to get one off and ran my finger into a hose clip. Now my finger is bleeding profusely. But this might be just becuase Im an idiot. ;-)
Old Feb 15, 2003 | 01:46 PM
dude, I know how that is. I slipped trying to wrench a bolt off trying to get my front bumper off and it gashed a big hole into my middle finger knuckle.
Old Feb 15, 2003 | 01:48 PM
Are there any disadvanteges to removing the header heat shield?Or the o2 sensor?
[Modified by slvrcivic97, 10:50 PM 2/15/2003]
Old Feb 15, 2003 | 01:49 PM
steve_s's Avatar
It got my pointer finger knuckle.
If your unclipping the harnest there is a mount that you need to take off holding the cable onto the block.
Old Feb 15, 2003 | 01:50 PM
steve_s's Avatar
[Modified by slvrcivic97, 10:49 PM 2/15/2003]
Just leave the O2 sensor.
kay_animation's Avatar
from my experience of taking off o2 sensors, taking it after it has been put in an aftermarket o2 sensor is pretty easy, but taking it off of a stock header is a bitch. Hope you have some formula 44 or something cause its really stuck in there so you have to loosten it up.
thanks.
Old Feb 15, 2003 | 01:52 PM
steve_s's Avatar
Default Re: Removing O2 Sensor (kay_animation)
If you just want the heat sheild off leave the o2 and unclip the harness. It is very very easy.
Is there any real reason for the heat sheild.
Old Feb 15, 2003 | 02:00 PM
Well, just took the heatshield off. It is very easy to do.
Old Feb 15, 2003 | 02:03 PM
steve_s's Avatar
What way did you use to get it through the o2 sensor?
Unclip the harness or take the sensor off.
Old Feb 15, 2003 | 02:06 PM
I just got the bolts undone. Sorry, I made it sound like I got the whole thing off. For the clip, do you just pull it apart really hard or is there something on it you have to push in?
Old Feb 15, 2003 | 02:12 PM
steve_s's Avatar
Pull on the whole thing towards the left it will slide off.
Then you need to push on the top and bottom and pull. It may take a little tugging.
I can take pics if you need me to.
Old Feb 15, 2003 | 02:19 PM
Thanks man, don't worry about the pics.
Old Feb 15, 2003 | 02:34 PM
95civicracer's Avatar
go to your local auto zone and and rent a o2 sensor socket and remove it with that, it makes it much easier. take the header off first.
[Modified by 95civicracer, 11:35 PM 2/15/2003]
zerodohc
Jan 10, 2013 12:41 PM
Cambocheen!
Feb 28, 2009 10:13 AM
beandip
Feb 20, 2006 10:00 AM
EJAYATE
Jun 1, 2005 03:51 PM
sleeperek
Oct 24, 2004 08:50 AM
