84.5mm combustion chamber and 84mm bore
I'm running a 84.5mm bore and a 81mm combustion chamber. It will cause the engine to detonate easier, but to counteract this i have to bump my timing curves down a bit. Its a 150.00 dollar option from Portflow. I would recommend you doing it, i just did this on my all motor engine with a 86mm bore.
[Modified by boosted hybrid, 12:51 PM 2/15/2003]
I'm running a 84.5mm bore and a 81mm combustion chamber. It will cause the engine to detonate easier.
[Modified by Speed PHreak, 2:10 PM 2/15/2003]
Well in my case, the head would be bigger than the bore. I am looking at buying a head that has already been opened up to 84.5 while my bore on the block will be only 84mm.
-S
-S
You will have zero problems. The .5mm is barely noticable. The 3.5mm difference on my engine is very noticeable of a lip. I wish the head was opened up, but its to late to have it done.
My compression ratio is around 8.8:1~9:1 with my set-up. I havent run it yet so i cannot comment on how badly the detonation will occur. Theortically the lip of the combustion chamber will get hot, letting the mixture pre-ignite. Think of it as the carbon build-up holding heat in the combustion chamber, they are associated with detonation.
I actually like it there. I do round it off a little bit jsut to take off any sharp edges. I would think it would help coompress everything towards the center of the chamber where it should be. I opened it up on my last motor and i didnt notice a bit of difference.
TurboAce
Dec 25, 2004 08:56 AM
rjay8604
Sep 6, 2004 11:15 PM
Desperado
Oct 4, 2003 09:07 AM
