Good setup or no
Is this a good setup b16 head with a b20 block
-b16 tranny
-type r valvetrain and cams
-ctr pistons with eagle rods
-frankenstein ecu redlining at 10000
- type r intake manifold
- fuel reg with type r injectors
sorry for posting here but just thought u guys would know about this also could i get better cams making power at like 9000+ with a good valvetrain with the ctr pistons and eagle rods but with a stock block and type r injectors
-b16 tranny
-b16 tranny
If you plan on building the motor run Probe Ultralite rods. Same price, but lighter. Or get cunningham if you got the $$$. If you wanna run more then 12:1 compression you are gonna have to sleeve the block.
What kind of compression are you looking to run? I'd say maybe 11:1 or so tops with ITR valvetrain. I would do a B20 bottom w/ Probe rods, Wiseco 11ish:1, get a B16 head, port work, ITR valvetrain and Hondata with the rest parts to go with it.
[Modified by Mr Milano, 9:47 AM 2/15/2003]
If you do end up w/ CTR pistons, no need for Eagle rods. Just get ITR rods.
streetracerof06
Feb 2, 2006 05:08 PM
pushr0djunk
Feb 15, 2003 05:40 AM
