Guys with Ground Controls
Old Feb 14, 2003 | 11:57 PM
SSBP DC2's Avatar
Default Guys with Ground Controls
hey guys, i need to ask you guys for a favor.
for those of you that has Ground Control, could you please post the spring number for the front and the rear? i'm just wondering if the guy gave me the right springs since i just got my setup today.
TIA guys
-demitri
Old Feb 15, 2003 | 08:28 AM
PM-Performance's Avatar
Default Re: Guys with Ground Controls (SSPB DC2)
they shuld have em on the site. check there, some guys order diff spring rate so that mght not help you by asking thme the spring rartes
Old Feb 15, 2003 | 10:37 AM
IC x Prince's Avatar
New User
Default Re: Guys with Ground Controls (itr206)
yeah, or look on the box..mine had a sticker on the bottom of the lid. or underside.
Old Feb 15, 2003 | 05:23 PM
SSBP DC2's Avatar
Default Re: Guys with Ground Controls (UltraPrince)
no, on the site it has a different number
yes, on the box there's a number, that's why i'm trying to figure out what set i have. how else was i suppose to compare them?
anyone else?
-demitri
Old Feb 15, 2003 | 09:58 PM
EvilIntegrationLS's Avatar
there should be a piece of paper that comes in the box that should have instructions and part #'s on them that specify's which springs go in the front and back. mine did
Old Feb 15, 2003 | 10:00 PM
UnionCity LS's Avatar
Default Re: Guys with Ground Controls (EvilIntegrationLS)
sorry i wouldnt know...but i do got em...
Old Feb 16, 2003 | 12:04 AM
SSBP DC2's Avatar
Default Re: Guys with Ground Controls (UnionCity LS)
*sigh* maybe you guys misunderstood my question.
I know the part numbers, i know which one goes in the rear and front
i know the spring number
my question is did i get the right kit. The box said it's the right kit, but the springs inside can still be swapped around. I'm requesting the spring number on both the springs (front and rear) for comparison purposes.
my fronts = GC200.64.67
my rears = GC180.64.44
are these numbers right for integras? i'm just a little concerned because i've never bought anything from this new shop before, just affraid they'd swap me some civic springs (softer rates)
Thanks all
-demitri
Old Feb 16, 2003 | 09:15 PM
SSBP DC2's Avatar
Default Re: Guys with Ground Controls (Dc2Teg)
again, i'm not asking for the color/where to look for the numbers etc....
i know all that...
i'm asking for a favor from the GC owners to post their spring numbers for their tegs for comparison purpose
Old Feb 17, 2003 | 07:07 AM
JDubya's Avatar
while we're on the subject, can someone tell me what spring rate these Eibach springs are? they say 44/99 0600.250.0700 They're 600 pounds right? and what does the 44/99 mean? thanks.
Old Feb 17, 2003 | 11:10 PM
ghettols's Avatar
this is off from what you are asking, but how much did you buy your ground controls and where did you buy them from??
[Modified by ghettols, 8:10 AM 2/18/2003]
Old Feb 18, 2003 | 12:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Guys with Ground Controls (ALL MOTOR LS)
That should be a 6" free length spring, 2.5" inside diameter, and 700 lb/in spring rate. Those are going to be too stiff for any off the shelf shock that I know of, even the Koni Sports would probably need revalving to handle those rates. I don't know what the 44/99 is.
ConfusedEGCoupe
Suspension & Brakes
11
May 31, 2012 06:20 PM
oak1now
Suspension & Brakes
Jun 18, 2007 06:52 AM
Sean @ ESG
Suspension & Brakes
17
Feb 11, 2007 10:00 PM
Jeff99Base
Sep 26, 2005 06:54 PM
Toadfart
Jan 22, 2004 01:42 PM
