Painting moldings on a honda ...
Old Feb 14, 2003 | 10:44 PM
mtkversion's Avatar
Default Painting moldings on a honda ...
wanted to re-paint the moldings on my car after an accident scuffed them up.
I would usually sand the molding down, clean it with goo-b-gone, then paint a few coats, then put on the clear coat.
It seems to work fine but after a few months it gets dingy and ugly.
Whats the proper way to ensure a good clean paintjob on a plastic molding without an expensive plastic adhesive.
Any thing that they would sell at a Kragens or Pepboys that acts as an adhesive thats a few bucks a can?
Old Feb 14, 2003 | 10:53 PM
MTK Kommander's Avatar
Default Re: Painting moldings on a honda ... (mtkversion)
my korean kounterpart.. next time use clearcoat
Old Feb 14, 2003 | 10:58 PM
mtkversion's Avatar
Default Re: Painting moldings on a honda ... (MTK Kommander)
I used clearcoat the other times ... still dulls and gets ugly.
I'm guessing that the paint doesn't " stick " to the plastic well enough ....
Old Feb 14, 2003 | 11:04 PM
civic dx's Avatar
i did not use clear, mine still looks good
Old Feb 14, 2003 | 11:20 PM
iam7head's Avatar
Default Re: Painting moldings on a honda ... (civic dx)
lol is because you dont know how to apply clearcoat.
a light coat will look dull but a evenly rich coat will have the
shiny finish.
I used to not use clearcoat since it looks shiny and all the good stuff, but
the clearcoat give it a much better protecton from weather and rock chip.
it hold the paint in place.
use the best material you can get
also use a good primer/paint base.
i used those primer for bumper and molding because he have "flex" in them,
they stick better and have little more flexiblilty.
painted
value cover, water squiter, both oem side skirt, front lip, eye lip, mud flops, rims, brake caliper(sp?) and other tiny bitchy stuff.
Old Feb 15, 2003 | 07:13 AM
Nameless RB26's Avatar
Default Re: Painting moldings on a honda ... (iam7head)
NO - it's because you're using spray paint.
You'll NEVER get the right finish and hardness that "car" paint will give you. EVER. No matter how good you paint it and how many clear coats you use...
So.. you should probably have it painted professionally.
This is a procedure for painting in a shop:
Clean
sand
clean
bondo
sand
primer
sand again if necessary
primer again if necessary
sand with high grit paper
clean with "scrubby" pad
paint
Not:
sand
spray primer
paint
spray clear
Old Feb 15, 2003 | 07:54 AM
civic dx's Avatar
not because i don't now how its not its just not needed.
Old Feb 15, 2003 | 10:06 AM
mtkversion's Avatar
Default Re: Painting moldings on a honda ... (Nameless)
well it is " car " paint, just in a spray can.
i don't see the difference that would make it different except from the adhesive they use to make paint stick to plastic.
i'll just sand more thoroughly and let it dry longer than usual ....
Old Feb 15, 2003 | 12:02 PM
iam7head's Avatar
"Clean
sand
clean
bondo
sand
primer
paint"
forgot cleaning alcohol...
lol dont we know about this already?
Old Feb 15, 2003 | 12:04 PM
iam7head's Avatar
"not because i don't now how its not its just not needed."
My statement are not attacking you or something, it just the
way i was taught.
Old Feb 15, 2003 | 01:40 PM
Did you have it made and put into a spray can?
dem0nk1d
Paint and Body
Apr 15, 2011 03:21 PM
tekniq
Paint and Body
Oct 11, 2008 04:34 PM
f22 lx
Jun 2, 2005 04:53 PM
Buktheng
Mar 6, 2005 11:17 PM
mtkversion
Feb 14, 2003 10:46 PM
