clamping the brakes
Old Feb 14, 2003 | 10:00 PM
sshaikh01's Avatar
Default clamping the brakes
how are you suppose to compress the brakes with the c-clamp.
Does anyone have a pic of a setps or something.
Becuase i pull my brakes apart, and one brake pad fell off, i put it together, and but there wasn't enough clearance to fit it on the rotor, so i thought let me use force on this hoe and made it fit, and thought maybe it'll adjust itself.
But it didn't, and now when i drive, i hear that lovely sound ssshhhh ssshh sssshhh
I know if i drive like this, i will only wear out my brake pads.
So my resolution would be to get that c-clamp and compress it (am i correct) if so how.
[Modified by sshaikh01, 1:03 AM 2/15/2003]
Old Feb 14, 2003 | 10:06 PM
IWearMyKswiss's Avatar
New User
Default Re: clamping the brakes (sshaikh01)
wrap the Cclamp around the caliper having the floating piece on the C clamp go on the piston,..turn the rod till the piston is in,...once you are done,..make sure you pump your brakes before you drive to get the piston to lay on the backing plate of the brake pad
Old Feb 15, 2003 | 09:27 AM
sshaikh01's Avatar
Default Re: clamping the brakes (WiDeBoDyEK)
thanks
dizzi
Nov 20, 2012 06:30 PM
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
leekor12
Apr 19, 2007 07:05 PM
splink
Aug 21, 2004 06:49 PM
uNF$@#!
Apr 28, 2003 12:17 PM
