B16B into a '92 Civic VX ... swap questions.
Old Feb 14, 2003 | 07:42 PM
AdamITR's Avatar
Default B16B into a '92 Civic VX ... swap questions.
Just some questions I was hoping someone could answer.
1. The VX model has something called a "Devce Control" ... do I need this anymore? I have no idea what this does ... but there is a spot for the wiring harness to plug in. There are also two rubber lines that come out of it.
Here's what I'm talking about:
2. The B16B motor came with no PCV setup ... missing everything. What are my options. I have the pcv system from the Civic VX motor. The stuff below.
3. I was installing the fuel line breather tank, but have no idea where hose #46 goes?
Thanks
Old Feb 14, 2003 | 08:06 PM
VTECVillain's Avatar
Default Re: B16B into a '92 Civic VX ... swap questions. (AdamITR)
Unbolt the top #3 box from the firewall and throw it in the trash, you no longer need it.
Old Feb 14, 2003 | 08:09 PM
AdamITR's Avatar
Default Re: B16B into a '92 Civic VX ... swap questions. (VTECVillain)
Great ... I was hoping that was the case.
Old Feb 14, 2003 | 09:57 PM
Patrick's Avatar
Yeah, no need for that bad boy, its for the egr, I just took mine off and Ive had my swap for 5 months, Im just lazy.
You should just do an oil catch can if you have the cash.
S13 slide
Apr 21, 2005 12:14 PM
2muchPSI
Mar 4, 2003 06:00 PM
