B16 Tb on d series???
Old Feb 14, 2003 | 06:41 PM
Red_Si's Avatar
Default B16 Tb on d series???
Ok, i know you can use the b16 tb on a d series but what sensors do i need. do i need all the sensors that were on the b16 tb in the first place or just the tps??? thx and let me know
Old Feb 14, 2003 | 09:59 PM
Louie B.'s Avatar
Default Re: B16 Tb on d series??? (Red_Si)
ONLY if the d-series intake manifold you're using is '92 or newer, 88-91 have a different bolt pattern.
Old Feb 14, 2003 | 10:27 PM
Mugen Dom's Avatar
Default Re: B16 Tb on d series??? (thumpu77)
yeh thats correct and itll bolt onto the z6 intake and y8 intake no problems just need to plug it into the tps plug
Old Feb 15, 2003 | 10:15 AM
Red_Si's Avatar
Default Re: B16 Tb on d series??? (JdMB16Ahatch)
ha, good luck i have a y8 manifold! so i only need the tps right? do i need the map sensor?
Old Feb 15, 2003 | 06:54 PM
Mugen Dom's Avatar
well u can use the map sensor on the throtlebody yes....u have to cause there isnt a port for ur old one to work with it if u use a newer b series TB
Old Feb 15, 2003 | 07:51 PM
my_slow_civic's Avatar
I just put on a tb from a 93' LS integra on my a6 manifold.
Old Feb 15, 2003 | 07:52 PM
Default Re: B16 Tb on d series??? (sirk)
too bad the damn pic doesnt show up. It can be found in here if anybody is curious
http://www.automotiveforums.com/vbul...915#post783915
Old Feb 15, 2003 | 08:37 PM
Red_Si's Avatar
so i do need the map sensor??? what are all the sensors that come on the b16 tb that i would need to use on the y8 manifold called?? basically how many sensors should there be, just the tps and map, or more???
Old Feb 17, 2003 | 02:12 AM
89civicdx's Avatar
dood you just bolt on the b16tb plug in the tps and you are good to go
use your stock map sensor
what gen b16tb do you have ...is it a 1st gen?If its a 1st gen then all it has on it is a tps.
you might have to "T" a vacum line though...I don't remeber exactly but its not a big deal.
[Modified by 89civicdx, 6:17 AM 2/17/2003]
Old Feb 17, 2003 | 04:45 AM
PaImportTuner's Avatar
do you mind explaining how you did this?? was it a direct bolt on? or what? what plugs need to be changed?
Old Feb 17, 2003 | 05:04 AM
89civicdx's Avatar
Default Re: B16 Tb on d series??? (PaImportTuner)
so if you are using ar 1st gen b16 tb
take a new gastket put it on the back of the B tb cut the gasket to the same size as the b tb put the gasket on the intake manifold and scribe the size of the new hole on the intake manifold. port match to the new scribed line. Clean everything up and put it all together. No plugs have to be changed.
Old Feb 17, 2003 | 06:44 AM
Mugen Dom's Avatar
Default Re: B16 Tb on d series??? (89civicdx)
if its a usdm b16TB then u have to use the map sensor attatched to the tb no matter what everything plugs in just have to extened the plug from the firewall no extra crap plug and play
Old Feb 17, 2003 | 12:36 PM
Red_Si's Avatar
ok thx guys i think i understand now!
Old Feb 20, 2003 | 08:23 PM
Red_Si's Avatar
ok, just clear one more thing up. if i use the y8 manifold and the 1st gen b16 tb it just bolts up??? i won't have to do anything else?
RipSiTurboHatch
Oct 27, 2005 12:09 PM
dcsports
Jun 24, 2005 10:16 AM
boosted k20
Jan 10, 2005 01:38 PM
Wes90civic
Jan 23, 2004 11:37 PM
Rob_hoody
15
Jan 27, 2003 07:33 AM
