whats better Ls or gsr with turbo???
Old Feb 14, 2003 | 05:36 PM
subhuman456's Avatar
Default whats better Ls or gsr with turbo???
ok i was asking around. people say a stock Ls turbo will rape a stock gsr turbo. can u guys tell me whats really up.
Old Feb 14, 2003 | 05:42 PM
djtony5's Avatar
Default Re: whats better Ls or gsr with turbo??? (subhuman456)
rape? i don't think so bud.
Old Feb 14, 2003 | 05:59 PM
VTECPWR's Avatar
Default Re: whats better Ls or gsr with turbo??? (djtony5)
GSR is better. Stronger internals, better flowing head, higher redline. Offset by better gearing in a LS (better for turbo) and in the GSR you have to be careful about tuning due to highers compression. But the higher compression will help turbo spool faster.
TeamTooQuick's Avatar
man think about it. Stock for stock, turbo for turbo, it should be like night and day. LS would get own'd...
Old Feb 14, 2003 | 06:20 PM
UnionCity LS's Avatar
whollleeeee **** hahah those "People" that say that...aint too smart now are they..Rape? the Gsr would bend a LS over and rape it..with a turbo? dam...we are talkin serious *** rapin...i love my LS but gatta give it to the Gizzers...
Old Feb 14, 2003 | 06:58 PM
b00sted4dr's Avatar
Default Re: whats better Ls or gsr with turbo??? (UnionCity LS)
haha.... just the gearing in the ls is better for turbo because its longer and maybe the lower compression might make it safer, but it would get owned by the gsr turbo.
Old Feb 14, 2003 | 07:28 PM
au-gsr's Avatar
Default Re: whats better Ls or gsr with turbo??? (96LsTeg)
neither try a powered wheelchair with a turbo
Old Feb 14, 2003 | 08:14 PM
threatcon13's Avatar
New User
Default Re: whats better Ls or gsr with turbo??? (VTECPWR)
GSR is better. Offset by better gearing in a LS (better for turbo)
whoever keeps on spreading that bullshit around really needs to stop. 95% of the time, a GSRs gearing will be better. and yes, stock for stock, turbo for turbo, GSR>LS.
Old Feb 14, 2003 | 08:18 PM
au-gsr's Avatar
Default Re: whats better Ls or gsr with turbo??? (Threatcon13)
threatcon is a bitch *** **** smokin grape smuggler
Old Feb 14, 2003 | 08:31 PM
meatball01's Avatar
Default Re: whats better Ls or gsr with turbo??? (au-gsr)
lets just put it this way. the ls has 140hp and the gsr has 180.
Old Feb 14, 2003 | 08:33 PM
SMZ GSR's Avatar
whats your problem man... i have yet to see you post something that actually helps someone. all your recent post have been retarded comments and smartass remarks. if you're not going to help someone with a serious question, then dont even bother replying just to boost your post count
Old Feb 14, 2003 | 08:35 PM
New User
Default Re: whats better Ls or gsr with turbo??? (BallenDaW.C.WitPac)
gsr has 170.
Old Feb 14, 2003 | 08:39 PM
SMZ GSR's Avatar
gsr has 170.
plus HP isn't everything. GSR engine is VERY different to a stock B18B. plus the transmission plays a factor.
Old Feb 14, 2003 | 08:43 PM
StyleTEG's Avatar
Default Re: whats better Ls or gsr with turbo??? (SMZ GSR)
so much misinformation
first off which turbo kit makes a difference.
Your running on a stock engine, so chances are you are going to be in the 7-8psi neighborhood.
A smaller turbo is going to spool faster, and have a broader powerband. That is a huge advantage.
B18B has lower compression ratio which means its safer to run more boost with out reenforcing the internals. (assuming its proper tuned of cource)
The LS transmission is not better for boost unless you are dealing with tons of boost (probably more than 20psi), which you won't do on a stock transmission.
Old Feb 14, 2003 | 08:44 PM
B00ST2nR's Avatar
You slap a Turbo on an Integra LS, and you slap a Turbo on as Integra GS-R, I gaurantee you the GS-R would win.
LS Turbo is good because its cheaper and you can boost more because of the low compression. Get the facts straight.
Old Feb 14, 2003 | 08:56 PM
New User
Default Re: whats better Ls or gsr with turbo??? (Skunk2nR)
no point in boosting more at low compression....same thing as boosting low on high compression. so thats not a valid advantage for the ls.
Old Feb 14, 2003 | 09:03 PM
Aaron M's Avatar
Terms of Service:
"Do not incite riots or instigate fights. Please do not refrain from heated discussions but do not intentionally start antagonistic or inflammatory threads directed at another member"
Old Feb 14, 2003 | 09:15 PM
illi Adik's Avatar
this is the most retarded thread i have ever seen, soo many noobs spreading false info.
Old Feb 14, 2003 | 09:19 PM
spd18's Avatar
Default Re: whats better Ls or gsr with turbo??? (SilverB18C1)
the only reason that an LS would be better for turboing than a GSR is because of its lower compression. besides that, the gsr is better in every way. the "LS's tall gearing is better for turbo" myth needs to stop.
Old Feb 14, 2003 | 09:23 PM
New User
Default Re: whats better Ls or gsr with turbo??? (spd18)
thanx newbie
Old Feb 14, 2003 | 10:10 PM
boostedsol's Avatar
it depends on the set up. what size turbo???? stand alone or fmu???? tuned or not. stock for stock, the gsr is a better motor, but the ls can hang as well. equal setups, a gsr on 6lbs and a ls on 8lbs, its going to be a good race....thats based on my experiances....both motors are great for boost, just have different capabilities.
trooper0641
35
Mar 21, 2004 12:21 PM
tencan
11
Sep 30, 2003 08:07 AM
mugensport9
Dec 22, 2002 07:11 AM
OriginalOboby
Jun 6, 2002 02:29 PM
dc516
Jun 19, 2001 09:38 AM
