Spoon Carbon Air Duct...
Old Feb 14, 2003 | 05:31 PM
Sima's Avatar
Default Spoon Carbon Air Duct...
I came across this carbon air duct piece from Spoon. I just couldn't figure out why they made it for the S2K and not for the Integra. Especially since there are a lot more Integra's than there are S2K's. Maybe some of you have seen it before, but this is my first time seeing it though.
Old Feb 14, 2003 | 06:10 PM
Reid's Avatar
Global Moderator
Default Re: Spoon Carbon Air Duct... (Sima)
Spoon does not make parts that they feel are unnecessary.
That is probably why you don't see a Spoon carbon air duct for the DC2.
Old Feb 14, 2003 | 06:16 PM
Sima's Avatar
Default Re: Spoon Carbon Air Duct... (Reid)
...unnecessary meaning that there wouldn't be any power gains with the system?
[Modified by Sima, 10:16 PM 2/14/2003]
Reid's Avatar
Global Moderator
Where are you thinking of adding said duct?
I don't understand your logic.
Get a Mugen intake if you want something similar.
Old Feb 14, 2003 | 06:18 PM
01-1293's Avatar
I think the placement of the s2000 engine makes that spoon duct more efficient than say on an integra
Old Feb 14, 2003 | 06:26 PM
Sima's Avatar
No, I was just wondering why they made it for the S2K and not for the DC2. But now that I think about it, I understand why...
Yea, I totally forgot that the engine placement on the S2K isn't the "norm" for Honda
Old Feb 14, 2003 | 08:44 PM
Hunter's Avatar
carl, why don't u get those motorsports engineering fella's down there to whip u up something special for ur DC2.
Old Feb 15, 2003 | 06:21 AM
Sima's Avatar
Default Re: Spoon Carbon Air Duct... (Hunter)
Hunter, that's b/c Business & Engineering students don't get along, j/k . I don't personally know any Engineering majors, but I may just have to find one on campus to come up with one. I like how it uses the stock air box with the duct going to the front bumper.
Old Feb 15, 2003 | 07:05 AM
Willard's Avatar
this is true.
I have been thinking hard about a 'duct' that goes in place of the factory 'white fender box' that hooks up to the stock air box and goes down to the area behind the turn signal.
Sorta like the ice box inlet... but only using the stock air box.
Will
-who is off to find a IMP shop.
Old Feb 15, 2003 | 10:30 AM
Mario's Avatar
On top of other possible engineering reasons behind it, consider this...
Obtaining a "ram air" effect whilst using the stock airbox on the S2000 is relatively easy. By simply going over the radiator support and down, the front grille is easily accesable for placement of the inlet and cool-air along with it. Even the Mugen airbox for the S2000 aims their intake towards the same area. However, theirs are designed to work in conjuction with their aero bumper, where there is a matching inlet integrated into the bumper.
Whereas on an Integra, there is no direct route (relative to the S2000 setup) from the stock airbox to an area of high pressure, where any "ram air" setup should be located. The Mugen/Comptech airbox places the inlet behind the turn signals. While you're getting cool-air in that area, to really take advantage of any "ram air" possibility with the aforementioned setups, one needs to remove/modify the turnsignal.
Old Feb 15, 2003 | 12:32 PM
UNCCchic's Avatar
Sima, email me
Old Feb 15, 2003 | 06:13 PM
Hunter's Avatar
Default Re: Spoon Carbon Air Duct... (ekchic)
Sima, email me
GO CARL!
Old Feb 15, 2003 | 06:30 PM
ALLMOTOR18's Avatar
or make one like I did..
i will get pics up soon..
Old Feb 15, 2003 | 06:46 PM
Reid's Avatar
Global Moderator
Default Re: Spoon Carbon Air Duct... (gsrtyper)
What did you make?
Is it just a DIY Icebox?
Old Feb 15, 2003 | 11:39 PM
tC_Dragon's Avatar
Default Re: Spoon Carbon Air Duct... (01-1293)
Old Feb 16, 2003 | 07:59 AM
Padawan's Avatar
Darth ModerVader
However, it does seem like Spoon chose CF for at least a slight "bling" effect, since the weight difference between this and an identical plastic piece would be negligible.
Crank
Oct 28, 2008 07:12 PM
GuCBlackEk
Oct 16, 2008 08:15 AM
justincredble
23
Apr 28, 2003 03:19 PM
str8rcn
Nov 25, 2002 10:36 AM
garagespecial
May 2, 2002 07:00 PM
