swap done , but a few problems
Old Feb 14, 2003 | 02:22 PM
GReddy SI's Avatar
Default swap done , but a few problems
1. my idle jumps from 1-2rpms when its in netural , what can that be some
2. i get a o2 sensor CEL , why? i am using my vx o2. with a vx harness,
3. when i am in gear , my shifter pops right out ? i have to like hold it in the gear so it wont come out , i am using b16a2 shift linkage.
4. holy crap , my car hauls *** like a ****
what how can i fix those problems?
92 civic vx hb motor b16a2 from 2k si , chipped p28 ecu
Old Feb 14, 2003 | 02:37 PM
splitime's Avatar
Default Re: swap done , but a few problems (GReddy SI)
2. VX is a 5wire o2, you need to rewire it some and get a 4wire o2 sensor. I used 2wires from the VX o2 plug and ran the other two straight to the ecu. I'll try to find my notes for you on that.
okie, i found the setup, the yel/blk wire needs to get routed all the way to the ecu, at least i found it easier to do it that way, then it gets t'd into the yel/blk on A and the yel/blk on B at the ecu. The other 3 wires you can use ones from the VX harnes, you'll have to make your own plug setup though, or just hardwire them. I bought a 4 wire waterproof wiring harness from pepboys, both the male and female then rewired both sides at the old plug area.
Okie, for 4 wire the wires are this:
Grn/Wht 2
Wht 1
Orn/Blk
Yel/Blk
for 5 wire they are:
grn/wht 2
wht
wht/blu 2
orn
orn/blu 2
yel/blk
blk 1
Okie for the the other wires, take the 5wire yel/blk and that goes to the 4wire orn/blk, grn/wht 2 is the same on both 5wire and 4wire, and orn/blu 2 is the wht1 for the 4wire o2. IM me if you need any more info.
btw. the above colors are directly from the helms, some of those cables are routed inside the cable plug so you dont think, gee thats more than 5wires...
I used this when i did a mini-me to convert the o2 sensor to 4wire. Should help remedy your o2 issue.
1. for the idle, it could be map and tps plugs mixed up, it could be a dirty fast idle valve, the unit under the TB. might be a vacuum leak also i think
[Modified by splitime, 3:38 PM 2/14/2003]
Old Feb 14, 2003 | 08:25 PM
GReddy SI's Avatar
anyone know more info , on what can be wrong ?
Old Feb 14, 2003 | 09:50 PM
IWearMyKswiss's Avatar
New User
from past experience the idle problem is do to the fast idle,..as for the popping out gear,..what gear is this doing it in??? if its doing it in only one gear then maybe the syncro is bad,...if its doing it in all gears then it could be that your using the wrong linkage
Old Feb 14, 2003 | 09:55 PM
BackSideSA's Avatar
Default Re: swap done , but a few problems (WiDeBoDyEK)
bad synchro's dude, had same problem a long time ago on my coupe
Old Feb 14, 2003 | 11:18 PM
GReddy SI's Avatar
its coming out on all of the gears, but if i hold the shifter while it's in gear everything is good , i am using a b16a2 shift linkage , which should work
Old Feb 15, 2003 | 09:11 AM
GReddy SI's Avatar
Old Feb 15, 2003 | 10:08 AM
976's Avatar
976
New User
Default Re: swap done , but a few problems (splitime)
...for the idle, it could be map and tps plugs mixed up, it could be a dirty fast idle valve, the unit under the TB. might be a vacuum leak also i think
Splitime pretty much summed that up. As for the gears I have no idea, but would like to hear what the problem was, bump...
Old Feb 15, 2003 | 10:49 AM
phantoman's Avatar
the manifold pressure can cause it to idle funny as well as the throttle, make sure on the intake maniold, the hoses are pluged to the right area, and the ones that arent used for obd2 are pluged up and not left open. because the on the 2kSi, they have a evap sensor and a pruge sensor that i dont think you will need, so you will have to reroute the hoses and stuff.
Old Feb 15, 2003 | 08:56 PM
GReddy SI's Avatar
Default Re: swap done , but a few problems (phantoman)
I think all of the plugs are in the right place , i think that i have that code 14 that i had in my 2k civic SI IAVC valve crap that is f.... ing with my car again , it only happens when it's really cold outside
Old Feb 15, 2003 | 09:03 PM
Mr. Shifty's Avatar
Make sure the coolant system is completely blead. This is a common problem to an erratic idle.
Sam1am26
Oct 18, 2005 01:45 PM
dturbo
Jun 8, 2005 06:16 PM
eggie75
Jan 5, 2005 05:54 PM
TriK
Jul 2, 2003 10:56 AM
