Pic Request: Underside of OEM style VIS c/f hood for Eg
Old Feb 14, 2003 | 01:38 PM
Fuster_Cluck's Avatar
Default Pic Request: Underside of OEM style VIS c/f hood for Eg
For those of you with a VIS OEM style hood on your EG's can you post a pic of the underside of the hood? I am really wanting to get this hood for my 93 Cx, but I am hearing the GSR motor will rub the hood. I need to see the underside and what kind of support bars are there. If someone has this hood and a GSR motor please post a pic of what you trimmed to clear the motor. I've read you can add washers to raise the hood a little. But, I also hear it doesn't look like a perfect fit once this is done.
If I decide to stay with the OEM hood will it rub the motor?
Thanks!
Old Feb 18, 2003 | 12:50 AM
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (Hybrid93Hatch)
To The Top!
Come on guys. Someone get off your lazy a$$ and go take a pic of the underside of the 3dr Eg oem style hood for me
Old Feb 18, 2003 | 03:03 AM
BenB's Avatar
Umm...No EG here. I have a B16 in my 96 DX, no clearance issues here. The skeleton of the hood follows the stock pattern and it works just fine for me. I am very pleased with the quality of this hood. I think you'll be ok man, and if not, it's no big deal to trim away on the fibgerglass supports to make it fit.
[Modified by BenB, 12:08 PM 2/18/2003]
Old Feb 18, 2003 | 05:42 AM
MrJasey's Avatar
To The Top!
i would but it is snowyyy
Old Feb 18, 2003 | 06:46 AM
HYBRIDHATCH92's Avatar
i'll e-mail you a pic its off my car right know and in my livingroom it does rub but it not that bad
Old Feb 18, 2003 | 08:10 AM
Vspec Sol's Avatar
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (HYBRIDHATCH92)
No you should not have any clearence issues. If there is then check if your motor is installed and leveled correctly. My friends car rubs with a b16 in it, but it is noticeably crooked. My brothers eg on the other hand has a GS-R and we had not problems cause we took time on that one and I can't say which shop did the b16 swap though. Basically you should not scratch and especially not with a stock hood.
Old Feb 18, 2003 | 08:55 AM
owen_the_soyboy's Avatar
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (Vspec Sol)
my gsr swap in my 92 cx rubs the underside of the hood only a little bit, like half the size of a nickel. I bet is the cf hood you want has any design similar to the oem hoods' underside, then you might rub. I dunno if other companies make 92-95 civic hoods that have no underside bars in the middle, but if there are, I would rather get one of those.
*My integra's cf hood from fiber images had great clearance... because there were no ribs in the middle of the underside.
Old Feb 18, 2003 | 08:59 AM
White Lightnin's Avatar
Mine fits allright. it fit great and didnt hit anything but then I was messing with my fuel filter and my FPR and now it wont close. So I got hoodpins. Thinking of selling it soon. Maybe painting over it when I get my paint done.
Old Feb 18, 2003 | 09:29 AM
ColdAccord's Avatar
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (White Lightnin)
bah, my vis hood is in my garage cause it's snowing. I'll get a pic if I can find someone with a digicam. The skeleton of the hood matches up identically to stock, or at least it appears to
Old Feb 18, 2003 | 04:36 PM
(teh)H2OUUP2's Avatar
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (ColdAccord)
VIS on a EH2 close enough to a EG....but I think the EG hood might be a little differnt b/c of the firewall....anyways I have no fitement issues and don't use hood pins and have been thru wind gust and high speeds on the Hwy.
Old Feb 18, 2003 | 04:42 PM
BackSideSA's Avatar
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (JDMSir-G)
wow....i didnt know there was a difference in the EG and EH hood
learn something new everyday
Old Feb 18, 2003 | 04:46 PM
sammysnakes's Avatar
the newest VIS hoods have actually changed the skeleton supports a little, so it might be different now.
i have a fiber images hood w/ no skeleton and it fits with a couple inches of clearence.
Old Feb 18, 2003 | 06:37 PM
ELUD THS's Avatar
New User
Default Re: Pic Request: Underside of OEM style VIS c/f hood for Eg (chainsaw)
ZCcivicBOI
Dec 16, 2007 05:07 PM
potatostix
Mar 29, 2006 01:05 PM
potatostix
Jan 3, 2006 12:56 AM
fcukmonsanti
Northern California (Sales)
Nov 14, 2005 09:02 PM
