How to get a stock B16a into the 13's...
Old Feb 14, 2003 | 11:14 AM
AussieK24's Avatar
Default How to get a stock B16a into the 13's...
http://www.pbase.com/image/12823066
Keep it light and wind it tight hehehe
Old Feb 14, 2003 | 12:42 PM
eccentric.ek's Avatar
Default Re: How to get a stock B16a into the 13's... (b16a4me)
yep i have seen stock b16a run 13s to many times aha, to easy
Old Feb 14, 2003 | 04:52 PM
MotorMatrix.com's Avatar
I am a bad person
put a gang of spray on it and run it till it lets go. this guy i know does it with gsr and type r motors and has run 10.7-11.0 on a stock motor in a very light 93 coupe.
Old Feb 14, 2003 | 05:11 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: How to get a stock B16a into the 13's... (MotorMatrix.com)
Thats hot.
Yes Matrix a gang of spray does WONDERS!
Old Feb 15, 2003 | 11:29 AM
civic disobedience's Avatar
Default Re: How to get a stock B16a into the 13's... (Stunna BEN)
I ran a 13.082 with my B16 on street tires... just add a turbo!!! worked for me
Old Feb 17, 2003 | 06:35 PM
EVOCELICA's Avatar
New User
Default Re: How to get a stock B16a into the 13's... (civic disobedience)
i've seen stock b16's run high 10's but no telling how long it will last
Old Feb 17, 2003 | 06:42 PM
Adam F's Avatar
Default Re: How to get a stock B16a into the 13's... (EVOCELICA)
Drop it off a building
[Modified by Proelite103, 9:42 PM 2/17/2003]
Old Feb 18, 2003 | 04:51 PM
.Chris.'s Avatar
Default Re: How to get a stock B16a into the 13's... (Proelite103)
wouldnt the building have to be at least a 1/4 mile tall??
Old Feb 19, 2003 | 02:01 AM
AussieK24's Avatar
I mean stock, no turbo, std intake, std TB, std B16a1 cams, std head, std pistons not stock with 40 psi blown into it
Old Feb 19, 2003 | 07:13 AM
JDM CRX's Avatar
take the b16 engine, (in its stock form) and put it in the trunk of a 13 sec car. i hate b16s BTW
Old Feb 19, 2003 | 06:39 PM
evilxkid's Avatar
Default Re: How to get a stock B16a into the 13's... (JDM CRX)
i hit a 13.7 with cams, springs, retainers, i/h/e. and that was a crappy run in my opinion. now with individual throttle bodies i'm working on my 12's with a stockb16 botom end.
Old Feb 19, 2003 | 08:42 PM
tinkerbell's Avatar
i think they have missed the point Chuck.
but hey, at least i know you have achieved your NA 13 second pass on a STOCK B16A with LOTS of hard work, not a open cheque book...
david..
Old Feb 19, 2003 | 08:50 PM
J_Edwards's Avatar
Default Re: How to get a stock B16a into the 13's... (tinkerbell)
IF you cut enough weight out of the car I am sure you could run 13's with a single cam...
Old Feb 20, 2003 | 12:04 AM
2.2EG's Avatar
well I happen to run mid 13's with my B16a , all I have done is raised rev limiter , CTR cams , springs and retainers Type-R intake manifold . Runs strong I just need to get cams , but I'm bulding a B20 when I get back from the Gulf
Old Feb 20, 2003 | 03:02 AM
anyone who replied that they run that kind of time has modified the head in some way, be it cams, or valve work, I think everyone also mentioned some sort of intake mods as well, and I would hardly consider ITB's a cheap mod... my point is that unless you have a 1200 lb car you are going to have to spend some money to run a 13 second E.T with a B16a
or put it in the trunk of my turboed B16a car...
[Modified by civic disobedience, 7:04 AM 2/20/2003]
Old Feb 21, 2003 | 12:02 PM
Nice_Dc2r's Avatar
Default Re: How to get a stock B16a into the 13's... (redUSDMhb)
i have a 92 cx w/ b16a i hit 13.8@101 w/ 2.06 60 foot
heres my set-up
i/h/e
quaiffe lsd
ats 1-3 gears
clutchmasters stage 3 clitch
clutchmasters flywheel
jdm type r final drive
jdm itr suspension changeover
tein ha coilovers
the car was semi stripped no back seat or passenger seat, and this was on 15 inch street tires@ 22 psi
Old Feb 21, 2003 | 12:11 PM
MADENGINEERING
Guest
Posts: n/a
went to golden eagle and bored it 87mm bore with some flat top pistons about 11:0.1 compression ported gsr head junn3 cams reprogrammed ecu and prelude injectors in a gutted crx ran 12.01 in palmdale should be 11.50 at sea level car weight was 1600 pounds w/driver engine made 190 hp to the wheels ,im a dealer w/golgen eagle...........................................Oh h ya thats a b16a stock rods and crank...........
[Modified by MADENGINEERING, 9:12 PM 2/21/2003]
Old Feb 21, 2003 | 04:59 PM
AussieK24's Avatar
NO intake mod (besides CAI), NO headwork.....STOCK MOTOR!!!!
I will run 12's with I/H/E/Standalone on a B16a1....
Old Feb 22, 2003 | 11:29 PM
93hybrid's Avatar
i havent run the 1/4 yet but i have a b16 with i/h/e and a fuel system. and my times for the 1/8th are in my sig. my problem is that i have a full race clutch in it with a light weight flywheel. so on street tires i spin way to much and it raises my speed but slows my et. hope this give a little help.
Old Feb 23, 2003 | 01:38 PM
Ruby Civic's Avatar
Default Re: How to get a stock B16a into the 13's... (93hybrid)
local car (86 crx) with b16 STOCK transplant ran 12.74 year before last, but that car was 1800 lbs. with driver...the horsepower is just not there without the mods, not to mention torque to get anything with weight off the line.
i ran 13.98 in a >2570 lb. 91 EX but had itr cams & intake manny with ctr pistons...
Old Feb 23, 2003 | 09:08 PM
JUNcr-x's Avatar
Default Re: How to get a stock B16a into the 13's... (Ruby Civic)
standalone and alot of wieght drop should do it!
Old Feb 24, 2003 | 04:02 AM
H25's Avatar
H25
getting a b16a into the 13 is easy. just drop it into a civic or crx. put some slicks and maybe a few bolt ons you will there no problem..you dont need as much as some people might think. i had a 94 jdm b16a in a eg before. all stock with the exception of cam gears, ram air, and chipped ecu, and normal 4-2-1 dc header. the car ran 13.1@103.86mph in feb of 1998 2000 lbs with driver.
Old Feb 24, 2003 | 05:36 AM
Gravy's Avatar
Default Re: How to get a stock B16a into the 13's... (LuckyRacing)
the only good thing about b16 they are a dime a dozen. try pushing one to the limit if it lets go 600 bucks for another motor.
Old Feb 25, 2003 | 11:12 AM
nsxmatt's Avatar
I have a B16 with I/H/E. Stock motor never opened, still running the stock clutch they sent with it. With slicks I could run 13's easy, and the car weighs 2000 lbs.
Old Feb 25, 2003 | 11:52 AM
CHRIS 1.8's Avatar
I know a guy that ran a 13.9 on a stock block B16a.
