What spring should i get???
Old Feb 14, 2003 | 10:24 AM
Red_Si's Avatar
Default What spring should i get???
ok, i'm gonna be getting some new struts and i was wondering how much lowering i can get away with with 14" wheels??? Should i just go with a coilover or is there a spring that has a good drop? I don't wanna be tucking but i don't wanna have too much of a gap! tia
Old Feb 14, 2003 | 10:47 AM
McD's Avatar
McD
Default Re: What spring should i get??? (Red_Si)
neuspeed race or h&r race, what struts are you going with?
Old Feb 14, 2003 | 10:52 AM
Ef Whore's Avatar
Default Re: What spring should i get??? (McD)
Go with my setup--Sprint Extreme Rx's--lays the car right on the tire(14's), with no gap, yet no tuck--they are perfect. Price is very affordable, and they are a quality spring. Got mine from http://www.ardperformance.com
Old Feb 14, 2003 | 06:17 PM
Red_Si's Avatar
Default Re: What spring should i get??? (Ef *****)
i'll check out the Rx's, i heard they lower the car significantly!! I'll also look at the h&R's and nuespeed. The struts i have are tociko blues, i know they aren't the best but i got a good deal!
Old Feb 15, 2003 | 12:09 AM
FullMetalJacket's Avatar
I run the regular sprints on my hb and they ride real nice..lower with about 1/2 inch gap on my 14 crx si alloys..i paid 100 for them new..i run H&R sports on my hb..they ride nice a lil stiffer than sprints..there more of a performance spring than the sprint..the gap is 1 1/2 with my 16's.. i ran skunk 2's on both with both tire/rim combos and they were nice but a bit stiff for tokiko blues..for ground control you would want konis or Illumnas I d stick with regular lowering springs for a street car
Old Feb 15, 2003 | 12:11 AM
Default Re: What spring should i get??? (FullMetalJacket)
btw with the sprints i have a lil bit of camber making my fronts wear a lil on the inside but not bad at all... the H&R's i have no camber wear since they sit higher...if you have decent tires and run some "race" spings invest in a camber kit
Old Feb 15, 2003 | 01:20 AM
FR-MOB: ThE bEe GuY's Avatar
I got the Sprint RX Extremes, gives a nice *** drop and it rides nice also. you WILL need a camber kit BTW. Also, itll blow your stock shocks out so your best bet would be to get some good adjustables...
Old Feb 15, 2003 | 07:32 AM
neutron91's Avatar
you should go with something like the eibach prokit, neuspeed sport, or h&r sport... anything that drops your car more than 1"-1.5" is gonna require quality adjustable struts... i don't think the blues would last very long... i have neuspeed race paired with koni yellows on my crx and i could only wonder how my ride would be with tokico blues... OUCH
Old Feb 15, 2003 | 10:16 AM
Red_Si's Avatar
Default Re: What spring should i get??? (neutron89)
so the tokico struts are no good, if i use the sprint rx's will they blow out right away???
Old Feb 15, 2003 | 10:24 AM
I think stuts blow mostly from spring rates being to stiff for the strut to handle and a lil from how low the spring drops it. Run the regular sprints. I wish I had a pic. The are a nice drop on my hb. Like I said only 1/2" gap or one small finger. Your struts will be fine on those. For the extremes you would probably want some Tokico Illumnas or Koni's
Old Feb 15, 2003 | 12:47 PM
rioninja's Avatar
I like the regular Sprints.
If i ever dropped my car again, thats
what i would go with.
tonysaur
Nov 14, 2005 01:34 AM
Xumarius
Apr 10, 2005 09:57 AM
abeaujuin
Nov 30, 2004 06:16 PM
EnKidu
Nov 22, 2004 09:40 PM
acatak
Mar 25, 2003 05:50 PM
