How to remove the SRS light.
Old Feb 14, 2003 | 08:27 AM
CW-ITR's Avatar
Default How to remove the SRS light.
Just installed the JDM GSR Steering wheel and ofcourse the SRS light comes on. How do you remove it without tear down the dash. Thanks guys.
Old Feb 14, 2003 | 09:19 AM
GokuSSJ4's Avatar
Default Re: How to remove the SRS light. (D)
would the samething apply to the check engine light ???
remove cluster. remove bulb. re-install cluster.
Old Feb 14, 2003 | 10:50 AM
RineRacing's Avatar
Default Re: How to remove the SRS light. (CW-ITR)
You can't get to the SRS bulb from the back of the cluster like the other bulbs. An easy solution is to unplug the yellow plug from the cluster. This will disable the SRS and ABS lights.
[Modified by Geratol, 11:50 AM 2/14/2003]
Old Feb 14, 2003 | 11:36 AM
jdmrealm's Avatar
New User
Default Re: How to remove the SRS light. (Geratol)
Yup this is the easiest way.
Old Feb 14, 2003 | 12:15 PM
Yellow3TypeR's Avatar
Default Re: How to remove the SRS light. (ej6)
Is removing an SRS steering wheel and replacing it with a non SRS bag illegal for street use?
Old Feb 14, 2003 | 12:53 PM
_unknown_'s Avatar
Default Re: How to remove the SRS light. (Yellow3TypeR)
Yes it is illegal.
You have to contact NHTSA for permission to remove your airbag.
You can also void your insurance coverage by removing the airbag without NHTSA approval.
If you do obtain permission you have to notify your insurance company and it is likely that your rates will increase.
I know this because I use to work in the legal dept of an automobile company.
HTH
Old Feb 14, 2003 | 01:28 PM
XR4racer's Avatar
yep, just reach up to the back of the cluster and feel for the little square plug(yellow) and disconnect. It will be on the right side of the cluster if you are sitting in the driver's seat. I just looked for it in the helms manual, realized it was the only yellow plug, reached up in the general area and unplugged it by feel, then checked the plug to make sure it was the yellow one.
Old Feb 14, 2003 | 05:34 PM
EK MONEY's Avatar
Default Re: How to remove the SRS light. (garth)
Yes it is illegal.
HTH
plus its unsafe
Old Feb 14, 2003 | 06:20 PM
uNF$@#!'s Avatar
Default Re: How to remove the SRS light. (Peagreenhatch)
removal airbags? unsafe?
i'd argue that point with a fine tooth comb.
either way, yes, if you fail to report it to the ins co, they can deny a claim easier.
if you report it, rates go up about ~$50 a year...atleast for me
Old Feb 14, 2003 | 08:45 PM
migs's Avatar
Default Re: How to remove the SRS light. (Soup ****)
2 minutes for the whole process.
Old Feb 14, 2003 | 09:58 PM
98type_r's Avatar
New User
Default Re: How to remove the SRS light. (Migs)
even easier process:
black electrical tape over top of the light
Old Feb 14, 2003 | 10:09 PM
MugenizedR's Avatar
If you are located in Los Angeles, I'll do it for
Old Feb 18, 2003 | 04:31 PM
JDM_ITR's Avatar
thanks for the info!
Old Aug 27, 2005 | 08:26 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: How to remove the SRS light. (98type_r)
Query: Removing the yellow plug does not affect the ABS in any way?
Old Aug 27, 2005 | 08:43 PM
.RJ's Avatar
.RJ
Default Re: How to remove the SRS light. (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Query: Removing the yellow plug does not affect the ABS in any way?</TD></TR></TABLE>
Not at all.
Old Aug 27, 2005 | 08:58 PM
uNF$@#!'s Avatar
Default Re: How to remove the SRS light. (jdmrealm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrealm &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Yo u can't get to the SRS bulb from the back of the cluster like the other bulbs. An easy solution is to unplug the yellow plug from the cluster. This will disable the SRS and ABS lights.
[Modified by Geratol, 11:50 AM 2/14/2003]&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
Yup this is the easiest way.</TD></TR></TABLE>
and it wont work on late model integras.
Old Aug 27, 2005 | 09:16 PM
Kendall's Avatar
I didn't have any problem removing the bulb from mine. It's been a while so i can't exactly remember what was involved, but it didn't involve anything that resembled difficulty.
Old Aug 28, 2005 | 03:47 AM
H-T Order of Merit
I'm gathering there must be a difference in the wiring between an earlier car and a later car?
My car has no bulb to be removed, but it's clear that a couple of people just removed a bulb and were fine.
So, what...97 and 98 have bulbs and 00 and 01 do not?
9.3.S.I.L.U.D.E.
18
Aug 20, 2009 01:50 AM
lsjon
Jun 17, 2009 02:11 PM
RineRacing
20
Jan 24, 2003 06:55 AM
ARACER25
May 4, 2002 09:25 PM
