do they even sell turbo timer wiring harnesses for honda's?
Old Feb 14, 2003 | 07:36 AM
ZCHF's Avatar
Default do they even sell turbo timer wiring harnesses for honda's?
I bought an apexi turbo timer and it would make things a lot easier if i had a harness. i dont know which two wires i am suposed to splice into and i dont know what IG1 and IG2 are. If i had a harness or new which wires were IG1 and IG2 then i would be fine, but i guess im just asking if they make a turbo timer harness for hondas? thanks
Old Feb 14, 2003 | 07:43 AM
ykracing's Avatar
Default Re: do they even sell turbo timer wiring harnesses for honda's? (ZCHF)
yes, they make one for honda... or at least they used to... I have one.
Old Feb 14, 2003 | 08:00 AM
ZCHF's Avatar
Default where
where did you get yours from?
Old Feb 14, 2003 | 08:30 AM
B18EG6's Avatar
Default Re: do they even sell turbo timer wiring harnesses for honda's? (trboCIVIC&WRX)
Thay have one that uses factors plugs, and no splicing??
Old Feb 14, 2003 | 08:35 AM
ZCHF's Avatar
Default (B18EG6)
b18,
did you splice yours?
thanks
Old Feb 14, 2003 | 08:36 AM
sydag5's Avatar
just splice, its only 5 wires.
Old Feb 14, 2003 | 08:38 AM
ZCHF's Avatar
Default thats the problem (sydag5)
i dont know which ones to splice.
i know which is the o2 and i know which is the ground and which one is 12v constant, and i also know which is the parking brake, but i dont know what the other 2 wires are. IG1 and Ig2, wtf is that? I read in my haynes manual and that book is all wacked out.
Old Feb 14, 2003 | 08:40 AM
B18EG6's Avatar
Default Re: (B18EG6) (ZCHF)
b18,
thanks
yes, i did. if you are really a neat freak, you could remove all the covers to the ignition, and solder them directly onto the ignition.
Old Feb 14, 2003 | 08:47 AM
ZCHF2's Avatar
Default why cant you respond to more than 5 questions in a 24 hour period?
i dont know which wires to splice? how did you know which ones to cut. i looked in the manual and it was tooo vague. also why can't you list more than 5 messages per 24 hours. how do you get authorized to do so. i had to create another account just to post on a message that i created. whats the deal with that? thanks
Brian
Old Feb 14, 2003 | 09:20 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: why cant you respond to more than 5 questions in a 24 hour period? (ZCHF2)
Apex'i Japan still makes one.
Old Feb 14, 2003 | 03:09 PM
B18EG6's Avatar
You cant post more than 5 times because of your status. You need to wait a little bit longer to be able to post more.
What car is this going into? I can tell you the colors of the wires maybe.
Old Feb 14, 2003 | 03:14 PM
ZCHF2's Avatar
Default crx hf
if you read my other post at 7:45 on this board it says what color wires i had coming off the ignition, the car is a crx hf
thanks
Old Feb 14, 2003 | 03:15 PM
TurbothisLS's Avatar
i was told that they did not make a wiring harness for a honda because it is not factory boosted
Old Feb 14, 2003 | 06:08 PM
accordfreak's Avatar
Default Re: do they even sell turbo timer wiring harnesses for honda's? (TurbothisLS)
use a volt meter and test each wire.
Old Jun 11, 2004 | 01:29 PM
killa_lude's Avatar
Default Re: do they even sell turbo timer wiring harnesses for honda's? (accordfreak)
i would like to know where i can get a honda harness (h22) for the hks timer type 1.
redh22alude
Apr 7, 2007 10:25 PM
turbojohnny
Jul 29, 2006 12:12 PM
egizzle8
Jul 9, 2004 12:08 PM
ZCHF
Mar 4, 2003 04:52 PM
The^Mad_Hacker
Aug 24, 2002 10:39 PM
