Brake light ON
Old Feb 13, 2003 | 11:07 PM
conesmasher's Avatar
Default Brake light ON
Hey, when it gets below about 15 degrees here in Col, OH, my cars brake light will not go off until my car has been warm for like 10 minutes or so. Pads are fine, Rotors are fine, fluid is topped off. Anyone have this problem or delt with it before.
Old Feb 14, 2003 | 02:09 AM
Nightscape's Avatar
Default Re: Brake light ON (snoballgsr)
I have that same problem rightnow with my gsr. Well, it's been doing that for few months now..but yea I don't bother with it because I know everything is working fine. Plus, i've heard of alot of integras having this problem-it's most likely a sensor thing...It only goes down to about mid 40's in the mornings here in so.cal but my light still stays on for about 3-4 miles...It will go off when i brake and come back on when i let off the brake..And then a couple blocks more down...it'll just go off...I should get it fixed while i still have my warranty though it's just that I'm too lazy and I know it's not big of a deal.
Old Feb 14, 2003 | 03:56 AM
Rory Breaker's Avatar
Default Re: Brake light ON (01Nightgsr)
Its either the fluid level being low (which you said you topped off) or the sensor on the underside of the cap went bad.
Old Feb 14, 2003 | 05:22 AM
IC x Prince's Avatar
New User
if it's under warrenty i would definetly get it fixed...it's free, why not.
Old Feb 14, 2003 | 05:24 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: Brake light ON (UltraPrince)
my car did the same when it was cold here....but has since stopped once my brake pads were replaced and the fluid filled back up
Old Feb 14, 2003 | 05:27 AM
usher13's Avatar
Yeah I would say this is a common problem. My gsr used to do this. The brake light would pop on and go off eventualy. It hasnt come on now for a while but im sure it will again some day.
Old Feb 14, 2003 | 07:15 AM
WOTTEG's Avatar
Default Brake fluid level
Same occurence to my integra once.
The MAX line in the brake fluid reseviour is NOT full. It needs to be "Topped Off" as you have said (Above the line to the top of the container). That cured it for me.
Old Feb 14, 2003 | 08:02 AM
97gSrkId88's Avatar
you should check ur headlight fluid
Old Feb 14, 2003 | 08:31 AM
Pineapple Devil's Avatar
Default Re: Brake light ON (97gSrkId88)
Mine did it but it was b/c when it got really cold out, my brakes would freeze close enough together to keep the light on. after driving for about 3 minutes it went off b/c using the brakes it heated it up
[Modified by Pineapple Devil, 12:55 AM 2/15/2003]
Old Feb 14, 2003 | 08:58 AM
EL Vap133's Avatar
Your brake fluid is low, refill it and the light will go off...
Old Feb 14, 2003 | 11:14 AM
shadowdawn's Avatar
Default Re: Brake light ON (Vap133)
Thank you for this thread I was gonna start one, just topped off my fluid, hopefully the problem goes away now .
As if the constant CEL wasn't bad enough the brake light had to join in for the past month
btman
Oct 12, 2007 06:11 AM
intech
Nov 17, 2005 02:44 PM
sullycrx
Nov 16, 2005 09:48 PM
HardSaltydogg
11
Jun 18, 2005 04:11 PM
Hairy Gorilla
Mar 31, 2003 08:57 PM
