usdm ITR block stamp
I'm pretty sure that usdm itr motors were B18C5 97-98 and 00-01
Am i right? Then where is the B18C3 from?
*edit: also, were the displacments the same? 17xx cc?
[Modified by Jawad, 10:06 PM 2/13/2003]
i have even seen two diff displacements in USDM ITR at the dealer.
Was that right?
Was that right?
what youve likely seen is 1797cc (gsr and itr) 81mm bore x 87.2mm stroke
and 1834cc (ls, gs, rs,se,) which is a b18 block with 81mm bore and 89mm stroke.
no i saw that it stated Type R next to the paper
[Modified by ace1875, 8:28 PM 2/13/2003]
and as for the B18C3, i believe this is the JDM factory replacement blocks, you'll see this a lot on Spoon balanced and blueprinted blocks.
slo97coupe
May 8, 2005 10:21 PM
