Cannot find right bulbs for 00' SI tails on 97 coupe
Old Feb 13, 2003 | 04:55 PM
phreaker's Avatar
Default Cannot find right bulbs for 00' SI tails on 97 coupe
Mmmm...put 00' SI tails on my 97 coupe and now my turn signals are white, which cops by the way do not like.
I have checked numerous stores and cannot find a amber bulb to replace it with, what am i to do?
Old Feb 13, 2003 | 07:41 PM
2000blackgsr's Avatar
Default Re: Cannot find right bulbs for 00' SI tails on 97 coupe (phreaker)
are you looking for an amber bulb for a 97? if so, look for the bulbs for a 99-00.
try looking for this http://www2.autozone.com/servlet/UiB...AR&PageSync=10
Old Feb 13, 2003 | 07:58 PM
IWearMyKswiss's Avatar
New User
Default Re: Cannot find right bulbs for 00' SI tails on 97 coupe (96coupe)
what i did was i went to pep boys and i went to the APC section (yea i know i know)APC makes a bulb for the turn signals that are amber,...if you dont want to do that then you can go to the honda dealership and get one i think
Old Feb 13, 2003 | 08:01 PM
tominos's Avatar
Default Re: Cannot find right bulbs for 00' SI tails on 97 coupe (WiDeBoDyEK)
you can get an amber bulb at any auto shop. just look up the 99-00 bulb.
Old Feb 13, 2003 | 08:05 PM
phreaker's Avatar
Default Re: Cannot find right bulbs for 00' SI tails on 97 coupe (tominos)
the 99-00 bulb does not fit..it has a little plastic clip on it that prevents it from sliding all the way in.
Old Feb 13, 2003 | 08:26 PM
Pravo2's Avatar
I had some left over model paint and painted my bulbs with a few light coats. The turn signal bulbs don't generate enough heat to 'burn' the paint so it's ok. I've had it for almost 2 years now and no problems.
Old Feb 13, 2003 | 08:30 PM
phreaker's Avatar
Default Re: Cannot find right bulbs for 00' SI tails on 97 coupe (Pravo2)
good idea ill do that. thanks.
Old Feb 13, 2003 | 09:04 PM
Yokohama's Avatar
my friend put the 99-00 tails on his 98 coupe and he has the amber blinkers...just go to autozone or whatever you have around and get the right ones for your wiring not the tails!
pjr710
Jul 22, 2006 01:29 PM
slo97coupe
17
Feb 27, 2006 11:44 AM
HCRX311
20
Sep 13, 2005 05:57 AM
abstracvision
May 6, 2003 02:13 PM
phreaker
14
Jan 8, 2003 09:57 PM
