replacement parts for jdm b16???
Old Feb 13, 2003 | 04:34 PM
bluecrxsi's Avatar
Default replacement parts for jdm b16???
anyone know a list or link to one, of what year/vehicle to ask for when replacing the commonly replaced jdm b16 parts????
Old Feb 13, 2003 | 04:36 PM
Hondasaurs's Avatar
Default Re: replacement parts for jdm b16??? (bluecrxsi)
DOHC Del Sol B16A3
Old Feb 13, 2003 | 06:28 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
{created by Honda-Tech member Monty}
[Modified by 88DXCRX, 9:30 PM 2/13/2003]
Old Feb 13, 2003 | 09:13 PM
T_Rex's Avatar
Default Re: replacement parts for jdm b16??? (88DXCRX)
Excellent post!! It will save people a lot of time and headaches
One question for you- The plugs I'm using are NGK BKR7E-11. What do you think of those?
Old Feb 13, 2003 | 09:49 PM
hatchii's Avatar
88dxcrx.. can you give me a list for USDM first generation b16a1 ? is it the same or not? thanks.
Old Feb 14, 2003 | 04:01 AM
EP3_05's Avatar
Default Re: replacement parts for jdm b16??? (hatchii)
Honda never produced a b16a1. The b16 in Japan was stamped as b16a and that is it. The first b16 in North America came in the del sol(b16a3). The last b16 came in the 99-2000 Civic Si(b16a2)
Old Feb 14, 2003 | 06:55 AM
paybac4223's Avatar
Default Re: replacement parts for jdm b16??? (91civic)
http://b16a.honda-perf.org/care.html
if that first post didnt cover it this should help
Old Feb 14, 2003 | 07:54 AM
Mr Furball's Avatar
Default Re: replacement parts for jdm b16??? (paybac4223)
Great info peeps.
Old Feb 14, 2003 | 11:03 PM
hatchii's Avatar
oh... so i have a JDM first gen b16? cause it's stamped b16A followed by 1 and a few more numbers...
Old Feb 15, 2003 | 02:28 AM
ULTRA911's Avatar
no numbers after the 'A' for jdm b16<U>A</U>
[Modified by ULTRA911, 11:28 AM 2/15/2003]
Old Feb 15, 2003 | 11:09 AM
paybac4223's Avatar
you may have a usdm b16
Old Feb 16, 2003 | 12:03 AM
hatchii's Avatar
well mine says b16a1xxxx so what is it? a usdm or JDM? i hear usdm and then a couple guys here say JDM... so what the hell?
Old Feb 16, 2003 | 11:37 AM
paybac4223's Avatar
im willing to bet my lunch money that you have a usdm b16....
oh and as far as gaskets and what not go ahead and use the 97 del sol vtec... the 94 del sol ones are for sohc models...(referring to the above link that i posted)
Old Feb 16, 2003 | 11:43 AM
vulcandan's Avatar
post a pic
Old Feb 16, 2003 | 12:07 PM
SiR Kid's Avatar
New User
Default Re: replacement parts for jdm b16??? (vulcandan)
I'd bet he's got this on his block
B16A
1003467
They SHOULD be over under like that.
Here's My JDM engine... It's an 89 SiR.
[Modified by SiR Kid, 3:09 PM 2/16/2003]
Old Feb 16, 2003 | 12:52 PM
hatchii's Avatar
Default Re: replacement parts for jdm b16??? (SiR Kid)
yes its
b16A
1001459
so what is it guys? and can i get the replacement parts for this? thanks
Old Feb 16, 2003 | 05:13 PM
irev210's Avatar
okay to help clear up a few things, you have a 1st gen XSI b16, made in 1989.
Old Feb 16, 2003 | 09:10 PM
hatchii's Avatar
Default Re: replacement parts for jdm b16??? (irev210)
xsi means?
Old Feb 16, 2003 | 09:32 PM
streetimports's Avatar
That's the type of car it came from (integra: model XSi) ... Just like our GS LS GS-R, they have their own codes...
Old Feb 16, 2003 | 09:49 PM
hatchii's Avatar
Default Re: replacement parts for jdm b16??? (streetimports)
umm so it's not Usdm?
Old Feb 16, 2003 | 10:43 PM
vulcandan's Avatar
That's right it's a first gen b16. Think of it this way. There was never a 1st gen b16 in US. So, everytime you hear 1st gen, think JDM. The numbers underneath "B16A" is the block number, like a serial number. I think the block numbers on the first gen's all start with 1xxx, and the 2nd gen's are 5xxx.
Old Feb 16, 2003 | 11:26 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
above was that 160 HP 1st gen B16A.. here's a 2nd Gen SiR II, 170 HP (hydro tranny) B16A.. i belive 92-95?
Old Feb 25, 2003 | 04:47 PM
paybac4223's Avatar
Default Re: replacement parts for jdm b16??? (Built B16A)
actually they made the sir II on a 92 jdm rsi with a cable tranny...
i have one and steve @ HMO got a shipment of about 15 of these motors
kim_2_da_chee
Mar 10, 2004 01:12 PM
luckybull
Dec 26, 2003 03:16 PM
conceptEG
Sep 4, 2003 10:44 AM
91hatchnewb
Apr 28, 2003 01:54 PM
Monty
Sep 7, 2002 05:41 AM
